C6 to Np435 swap, loose end questions.
Old 11-07-2011, 11:38 PM
nothercrash's Avatar
nothercrash
nothercrash is offline
So I've done my homework, got some money, blocked out some time, and learned to drive a standard......
I am just about to buy an Np435, with bellhousing, clutch, throwout, fork, and even the whole pedal assembly included.
I've looked up just about everything I can think of, but one thing I'm still wondering, is is my starter still going to work?
Let me know, thanks, AleX
Old 11-08-2011, 12:14 AM
boggin79ford's Avatar
boggin79ford
boggin79ford is offline
yes it will work. i just did this swap a few months ago it wasnt to bad minus a few snags with different pedal assemblies but well worth it.
Old 11-08-2011, 01:14 AM
nothercrash
Yeah? You really liked it??
I've been hard on the fence for a while. Built myself a niiiiiiiice C6, but then learned of the many joys of a standard.
Old 11-13-2011, 03:18 PM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is online now
The starters interchange but the manual & auto versions have different reach for the pinion to flywheel/flexplate distance.
Maybe it can work OK, but they are different.
I'm also doing a C6 to NP435 swap in a couple of weeks - it's been a long time coming.
boggin79ford - Did you notice much rpm drop after the swap, from eliminating the torque converter?
Old 11-13-2011, 03:48 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Don't know about rpm difference, but you will notice not having the C6 drawing off up to 50hp.
Old 11-13-2011, 05:10 PM
nothercrash
Ya I've been very much looking forward to that..... any idea how much the 435 saps though?
Old 11-13-2011, 06:20 PM
Ken Blythen
I've seen a list of figures for various transmissions' power consumption, saying even up to 65hp for the C6, & 15hp for the NP435.
There was debate on exactly how those figures were arrived at......but it's some comparison anyway.
I think the 65hp figure is a big block, drag racing type scenario.
Just a 2mpg gain & manual 'directness' will make me happy
Old 11-27-2011, 12:45 AM
Ken Blythen
nothercrash - did you make the manual swap?
Old 11-27-2011, 12:07 PM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,295 Likes on 1,095 Posts
X2 ?
Old 11-27-2011, 12:39 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
I noticed no difference in mileage or feel in power swapping from the C6 to the T19.
The grossly exaggerated figures for the C6 were from an early 80s Popular Hotrodding article and just eventually caught on like urban myth. Otherwise Chevy 350/400 trans and C4 would have significantly better MPG and drag racing times compared to a C6 equipped vehicle.
And that is nowhere near the case.
Don't forget the driveshafts are different, the NP435 is a lot shorter than the C6
Josh
Old 11-27-2011, 05:18 PM
nothercrash
Haven't gotten to the swap yet, hoping to start in the next few days, just trying to get the garage cleaned out for winter.
But Bullitt, I'd heard that alot before I bought this, and even the seller told me that was the case, but my C6 has a 6 inch tailshaft housing, and this 435 has about a 10". The two are actually identical in total length, with the bellhousing, trans, and tailshaft combined, about 26". This is just my sole example, but they seem to be out there, I was pleasantly suprised. This is in a married 4X4 setup.
AleX
Old 11-27-2011, 06:19 PM
Bullitt390's Avatar
Bullitt390
I could see a 4x4 C6 being the same length as a 4x4 NP435... In 2wd world there is a considerable difference in length.
Josh
Old 11-27-2011, 07:35 PM
nothercrash
Ah so that's probably where all the differences come into play, cool, thanks for the info.
Old 11-28-2011, 12:33 AM
Ken Blythen
Maybe with your 390 there was enough surplus power & torque to not have the C6 affecting performance?
I've just finished a C6 to NP435 swap this afternoon (behind a mild 351W), & I definitely got a gain in acceleration.
I also noticed a lift of 3-4 inches of vacuum climbing local hills at the same speed I normally would.
Too early for mpg figures yet.
Old 11-28-2011, 07:48 AM
Bullitt390's Avatar
Bullitt390
What 390? I sold the truck with a 390 but mostly had the dual quad 428.
The point is the article from years ago that eventually everyone took as gospel is flat wrong.
Also consider a guy who switches from a C6 to a race prepped C4 and only gains at most .10 in the quarter mile.
Josh
Quick Reply: C6 to Np435 swap, loose end questions.
