Speedometer Gear Choice (cable end)
Old Nov 7, 2011 | 03:07 PM
brandonmartin's Avatar
brandonmartin
I'm trying to dial in my '81 F100 speedometer. I recently found out that I have a B/W T18 transmission, a 9" rearend with 2.47 gears and tires that are 28" tall (30X9.50-15). I've been playing with speedo gears that I had left over from when I tinkered on 1965 Mustangs, Falcons, Comets, etc. A 20-tooth gear registered 35 MPH on my speedometer when I was actually going 50 MPH (GPS). I then installed a 16-tooth which registered 45 MPH on my speedometer when I was actually going 50 MPH. I just want to make sure I am heading in the right direction......I need less teeth on my speedo gear, right? 16 is the least amount of teeth that I have..........are there ones available with less teeth? I'm thinking 14 or 15?????
Thank You!
Old Nov 7, 2011 | 03:54 PM
f100jim's Avatar
f100jim
I am note 100% sure, but I think 16 is the lowest driven gear they made. You will probably need to change the drive gear. I think they come in 7, 8, and 9 tooth variety. To change it, you have to pull the drive shaft yoke out and remove the trans tail housing.
zingerr
Apr 29, 2013 06:35 PM
agaristo77
1978 - 1996 Big Bronco
May 3, 2012 08:04 AM
dreadinger
Jan 19, 2009 03:34 PM
imlowr2
May 2, 2008 08:24 AM
nate5812
Apr 15, 2005 04:02 PM
