Speedo Correction
Old Jan 19, 2009 | 02:32 PM
dreadinger's Avatar
dreadinger
Speedo Correction
I have a 1988 F150 5.0 C6 4wd 3.55 gears. I just swapped out the stock 235/75/15 tires for 31 10.5 15's. does anyone know what gear I need to get to make my speedo close to accurate?
Old Jan 19, 2009 | 03:34 PM
Ron W.'s Avatar
Ron W.
Pull the cable and driven gear, look at the end of the driven gear and count the number of teeth. Most will say a 1 tooth change will account for about a 3mph reading change.
I prefer to have a freind with an accurate speedo drive at 50mph, then look at my speedo to figure out how far I'm off. If his shows 50mph and I show 40mph I'm off by 20%, gives you a better idea of how your driven gear tooth count needs to be changed.
