1978 - 1996 Big Bronco
Speedo cable issues
Old Apr 23, 2012 | 11:37 PM
agaristo77's Avatar
agaristo77
Speedo cable issues
Hi all, just replaced the speedo cable in my 83, and.....it still doesn't register speed. When I pulled the old one out, it was chewed up at one end, with some wire sort of spun around the area where it plugs into the t case, and it was also worn, or melted through in an area. thought it would be a simple fix. am I to assume that the speedo drive gear is shot? or could it be an electrical issue w/ the printed circuit board?
thanks for the help!
Old Apr 24, 2012 | 01:06 PM
greystreak92's Avatar
greystreak92
Your speedometer is entirely mechanical. The wire you found splayed out in the end at the transmission could well have caused some damage to the speedometer gear. They are fairly easy to come by unless you have some odd axle gearing to compensate for.
Old May 3, 2012 | 08:04 AM
FourXFord2's Avatar
FourXFord2
The speedo gears are still available from the Ford dealers and the set is reasonable price, just changed mine last month (was non functional) You will need to know which color/ tooth count the gear on the cable is. If you have larger tires or have changed the gearing, now would be a good time to get the right gear so speedo runs right. Was informed that one step in tooth count affects the speedo by about 4.5 mph @ 60mph. So if your speedo is "slow" you need to go to a larger gear. My '91 has a yellow gear, 18 tooth,(I think) and is slow because of the stock gears and 33" tires so I've ordered the 20 tooth gear to get the speedo to read correctly.
Give me a holler if you can't figure out how to remove the inside gear.
PAwhiteboy
Feb 22, 2017 12:12 PM
Pappys53
Sep 23, 2010 07:43 PM
peterbilttrucker
27
May 3, 2009 02:01 PM
Shiny62
Bronco II
Nov 12, 2005 06:56 PM
nate5812
Apr 15, 2005 04:02 PM
