Cold weather Glitch or problem?
Old Nov 7, 2011 | 12:54 PM
Blade79's Avatar
Blade79
I have an 01 Explorer and when it is cold out it takes a while for my oil preasure gage to pop up and show preasure. Again this is only when it is cold out. Is this something normal or is this a sign of something else going on?
Old Nov 7, 2011 | 12:56 PM
Surge08's Avatar
Surge08
Maybe a sensor about to go bad, I would hook up a gauge and check what the pressure is and go from there.
Old Nov 7, 2011 | 06:10 PM
steve(ill)'s Avatar
steve(ill)
sometimes just an oil change will help. Do you use a 5 -20 to 10-30wt oil ? Dont go any thicker than 10 w-30.
Old Nov 7, 2011 | 06:53 PM
shorod's Avatar
shorod
My vote would also be on a bad switch. These don't actually use sensors, it's just a switch. Either the oil pressure is low or it's sufficient. Using a mechanical gauge to confirm would be good, but if you don't have any chatter or rattle at start up before the gauge reads pressure, chances are pretty good it's the switch.
Of course if you cannot remember roughly the last time you changed the oil then it wouldn't be a bad idea to change it before investing in a new switch....
-Rod
mwalpole
1978 - 1996 Big Bronco
Apr 29, 2008 09:26 PM
FordGP
25
Apr 7, 2008 08:42 PM
dfaint
1997 - 2003 F150
Jan 8, 2008 11:43 PM
penn
Aug 6, 2005 10:07 AM
milton
1997 - 2003 F150
Mar 13, 2003 07:10 PM
