low boost problem
Old Nov 7, 2011 | 09:25 AM
ford4x4956's Avatar
ford4x4956
low boost problem
been having a low boost problem, max boost is 10 psi on factory gauge and i can hear the vgt cycling the vanes at idle so i dont think the vanes are sticking and there are no cac or exhaust leaks....anything else u guys think i should check???? oh and i dont feel any power loss maybe bcuz im currently running SRL ++ tune
Old Nov 7, 2011 | 09:08 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Did it boost ok before the tunes were installed. Maybe dropping back to stock just to check it out might be a good place to start. Have you scanned for codes and do you have any gauges? Any recent work done?
Old Nov 7, 2011 | 09:28 PM
BLADE35's Avatar
BLADE35
I bet its been losing power over time its probably hard to tell
check and clean MAP,EBP sensors and tubes
I bet you will notice a Gain in power when the issue gets resolved
any gauges
Old Nov 7, 2011 | 10:26 PM
ford4x4956's Avatar
ford4x4956
boost was ok before and after tunes this just recently happened....havent check codes tommorow ill change it back to stock tune to see what happens
Pyroneer
20
Apr 22, 2019 03:53 PM
Jmatthews
6.7L Power Stroke Diesel
Jun 21, 2016 04:46 PM
KIDkiser
May 12, 2014 06:38 PM
StrokinWarmblood
Dec 15, 2011 12:09 AM
shendoa
Jul 17, 2004 12:21 PM
