auto window switch not working
Old Nov 6, 2011 | 07:34 PM
aristocraft's Avatar
aristocraft
ok so i just finished trying to get the auto function working on the 04 navigator but had no luck but a lot of new info. the regular window function works fine, just not the one touch. so i took the switches out and took the so i could ohm test them. the regular function ohm tested fine so then i tested each secondary switch for the one touch part and both of those worked fine. so i feel the switch portion is fine. i check the harness and it is getting power in the "auto" wire to the switches. so what i can tell, everything seems to be working fine in the switch area. so i cannot figure out why i am not getting the one touch action! what am i missing?? is there a "one touch" relay on an 04?
Thank you for any help
Old Nov 6, 2011 | 09:42 PM
Moto Mel's Avatar
Moto Mel
I'm pretty sure there is a one touch module in the driver's door circut and it may be bad.
Old Nov 7, 2011 | 08:05 AM
aristocraft
Thats what i am thinking is there must be a relay or module somewhere in the system, just gotta find out what and where.
Old Nov 7, 2011 | 08:28 AM
Moto Mel's Avatar
Moto Mel
I was looking for it in my manual and couldn't find it. It seems like it would be either in the door or the driver side kick panel.
Old Nov 7, 2011 | 11:28 AM
Moto Mel's Avatar
Moto Mel
You might want to check Ford Parts online with the keyword; power window module or one touch window module. sometimes they show a pic with other nearby parts and you might be able to locate it that way.
Old Nov 8, 2011 | 08:21 AM
aristocraft
I will have to check it, I have done a bit of googling on it but cant find anything which is frusterating. Thanks for the help. if you think of anything else let me know!
has a wiring diagram been posted so i can search it and see where the bad link could be?
Old Nov 8, 2011 | 01:57 PM
Moto Mel's Avatar
Moto Mel
Here's some more info:
<TABLE width="95%"><TBODY><TR><TD>SECTION 501-11: Glass, Frames and Mechanisms
</TD><TD align=right>2000 Expedition/Navigator Workshop Manual
</TD></TR></TBODY></TABLE>
DESCRIPTION AND OPERATION
<HR>Glass, Frames And Mechanisms
****** name=tps_proctitle content="Glass, Frames And Mechanisms">Glass, Frames and Mechanisms
[IMG]file:///C:/TSO/tsocache/MEL-PC_4436/SYJ~us~en~file=A0013962.gif~gen~ref.gif[/IMG]
<TABLE border=1 cellSpacing=0 cellPadding=3 width="70%"><TBODY><TR><TH vAlign=bottom>Item </TH><TH vAlign=bottom>Part Number </TH><TH vAlign=bottom>Description </TH><TR vAlign=top><TD>1 </TD><TD>— </TD><TD>Liftgate glass </TD></TR><TR vAlign=top><TD>2 </TD><TD>— </TD><TD>Rear quarter window glass </TD></TR><TR vAlign=top><TD>3 </TD><TD>— </TD><TD>Rear door window glass </TD></TR><TR vAlign=top><TD>4 </TD><TD>— </TD><TD>Front door window glass </TD></TR><TR vAlign=top><TD>5 </TD><TD>— </TD><TD>Front door window motor and regulator </TD></TR><TR vAlign=top><TD>6 </TD><TD>— </TD><TD>Rear door window motor and regulator </TD></TR><TR vAlign=top><TD>7 </TD><TD>— </TD><TD>Rear quarter window glass frame </TD></TR><TR vAlign=top><TD>8 </TD><TD>— </TD><TD>Rear quarter motor and window regulator </TD></TR><TR vAlign=top><TD>9 </TD><TD>— </TD><TD>Windshield glass </TD></TR><TR vAlign=top><TD>10 </TD><TD>— </TD><TD>Liftgate glass moulding </TD></TR></TBODY></TABLE>
The glass, frames and mechanisms include:
  • standard plastic and laminate safety glass
  • liftgate glass which houses the rear defogger grid
  • windshield glass which is bonded to the opening flange with a urethane sealant
  • standard power windows which include one-touch down and lock out feature
  • power vented rear quarter windows
  • fixed rear quarter windows (Expedition only)
  • RH quarter window glass antenna
The window regulator control switch:
  • is located on each door trim panel.
  • may be used to raise or lower all windows from the master control on the driver side, or the individual side window from the individual door switch.
  • includes a double detent feature.
  • can manually lower the driver side window when the master control is depressed halfway (first detent).
  • will completely lower the driver side window when the master control is fully depressed and then released (second detent).
  • can lock out passenger front and rear control switches.
The rear quarter glass regulator control switches:
  • are located in the overhead console.
  • may be used to open and close the RH or LH rear quarter windows.
  • stop the rear quarter glass in any position when released.
The power window system will operate if the ignition switch is in the RUN or ACC position, or the delayed accessory feature is active.
The generic electronic module (GEM) controls the opening of the LF driver side power window (window down motion) by activating the one-touch down (OTD) relay.
There are two modes of window down operation: manual mode and auto mode. The manual mode is selected by pressing the LF window switch to the first (down) position. In manual mode the window will move downward only while the switch is depressed. When the LF window switch is pressed to the second (down) position, it enters auto mode and the window will open completely with just a momentary press of the switch.
The GEM will activate the OTD Relay until one of the following conditions is met:
  • The LF regulator control switch is pushed to the UP position.
  • The LF regulator control switch is released (OFF position) and then moved to the down position (first detent) or one-touch down (OTD) position (second detent).
  • Seven seconds have elapsed since the OTD was initiated.
  • A window regulator electric drive stall condition is detected on the one-touch down sense line inputs.
The UP window operation is not controlled by the GEM. The feature is activated when the delayed accessory is active and the LF window regulator control switch is pressed to the UP position. The switch provides delayed accessory power to one side of the motor and ground to the other side through the one-touch down relay. The one-touch down relay is not active when the LF regulator control switch is in the UP position.
Passenger windows may be raised or lowered using the LF master control switches or the appropriate passenger window switch. Passenger window switches receive power when the delayed accessory relay is active and the LF remote lock-out switch is in the UNLOCK position. When in the LOCK-OUT position, the passenger windows are deactivated.
The GEM controls manual down and auto down window movement with the down window relay. The relay is activated by applying ground directly to one side of the down window relay coil, and deactivated by removing the ground signal.
The delayed accessory relay provides power for the operation of the power windows and the power moon roof. The delayed accessory feature is active when the ignition switch is in the RUN or the ACC position, or when the ignition switch is changed from RUN or ACC to the OFF/LOCK position and the LF and RF doors are closed.
The GEM will deactivate the delayed accessory feature when:
  • the LF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • the RF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • 10 minutes have elapsed since the ignition switch was changed from ACC or RUN to the OFF/LOCK position.
Feature inputs:
  • LF door open warning switch (open circuit with door closed, grounded with door ajar)
  • RF door open warning switch (open circuit with door closed, grounded with door ajar)
  • ignition switch RUN position (battery potential on both the RUN and RUN/ACC inputs)
  • ignition switch ACC position (battery potential on the RUN/ACC input)
  • ignition switch OFF/LOCK position (absence of battery potential on the RUN, RUN/ACC, and START inputs)
Feature outputs:
  • delayed accessory relay (grounded when activated, open circuit when deactivated)
The GEM controls the rear window defrost grid and heated mirrors by controlling the state of the rear window defrost/mirror relay. When the rear window defrost switch is pressed, the GEM will activate the heated grid relay. When the heated grid relay is active, both the rear window defrost grid and heated mirror elements will be energized.
The GEM will deactivate the heated grid relay when one of the following conditions is met:
  • The rear window defrost switch is pressed when the feature is active.
  • Ignition switch state is changed from RUN to OFF/LOCK.
  • The 10 minute timing function is completed.
Feature inputs:
  • ignition switch RUN position (12V on both RUN and RUN/ACC inputs)
  • rear window defrost/mirror switch (momentary contact to ground when switch is pressed)
Feature outputs:
  • rear window defrost/mirror relay control (grounded when activated, open circuit when deactivated)
Old Dec 28, 2011 | 11:08 PM
aristocraft
Ok So I have spent countless hours searching for the relay after you posted this info ( thanks by the way) but cannot locate it. It must be the problem but cannot locate it anywhere!!!!
Metal twister
18
Aug 8, 2016 12:39 PM
Xerophobic
Oct 5, 2012 08:41 AM
viker123
1997 - 2003 F150
Apr 17, 2011 09:05 AM
GRNMSTR
2004 - 2008 F150
13
Jun 29, 2007 12:04 AM
bigric
Electrical Systems/Wiring
Jul 2, 2003 10:59 PM
