Hard Start, No Start
Old Nov 6, 2011 | 05:24 PM
Incom_98's Avatar
Incom_98
OK Folks, I read through a ton of these posts about hard start to no start situations, I am in the same boat as many of the others, I did heed the other posts info and ran some tests on mine so here is what I am looking at.
2006 Ford F350 6.0 Diesel, before it got cold down to the 40's at night it would run really ruff for about 15 min sluggish throttle control, dealer said that was normal till it got warm, now that the temps are dropping to low 30's at night it is not wanting to start in the mornings sometimes, not all the time though, and when it starts there is very little white smoke blowing, ran the FICM tests that was recommended here are the results.
BATT Cold both were between 12.5 and 12.8 VDC
FICM check w/o key in 47.8 VDC
FICM check w/Key on w Buzz 22.5 VDC
FICM Crank 45.5-46.5 VDC
The oil was just changed @122038 by a Ford dealer and fuel filters were changed using motor craft filters.
The only other thing I can mention is that I have noticed that if the vacuam pump does not come on when I turn the key that the truck won't start if it does then it starts but runs ruff for about 10-15 min, I have checked for vacuam leak and cracked lines but have found nothing.
So there it is, any Ideas or checks that you can come up with would be great, getting ready to take it to the dealer to get it put on a machine, unfortunatly Autozone didn"t have the SD2 in so I put it on order.
Andy
Old Nov 6, 2011 | 05:47 PM
pappy19's Avatar
pappy19
You should copy and post this on the 6.0 heading and you will get a better response.
Pap
Old Nov 7, 2011 | 07:13 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Nov 7, 2011 | 01:23 PM
davidkstyler's Avatar
davidkstyler
Andy
FICM bad, should be 48v at all times.
See https://www.ford-trucks.com/forums/8...procedure.html
Read this to see if you want to repair it
https://www.ford-trucks.com/ford-manuals/FICM.pdf
deputydog03
May 31, 2017 04:50 AM
davbeisner
Jan 5, 2016 10:15 PM
TNT
Jan 18, 2012 01:28 AM
Incom_98
Nov 13, 2011 04:43 AM
raginout2
Aug 8, 2009 10:32 AM
