6.9 weird engine noise
Old Nov 5, 2011 | 07:49 PM
pws's Avatar
pws
hi after doing an extensive search i cannot.find the answer,today my truck was filled with fire wood and when i was going down the road it started making a noise kind of like when a gas car is over heating.it would do it then quit.it did it several times and when it was doing it it was smoking out the exhaust really bad.i let off the fuel pedal and it eventually quit .the temp gague was in the normal position and the oil pressure was good .im new at diesels.thanks in advanced .
Old Nov 5, 2011 | 08:20 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Was it like a knocking sound?
Might be an injector getting stuck open once in a while.
What's the mileage on the truck?
Old Nov 5, 2011 | 08:38 PM
pws's Avatar
pws
yes kind of a knocking noise it scared me i cannot have this thing blowing up on me
Old Nov 5, 2011 | 08:42 PM
IDIDieselJohn
It won't blow up, but it will do damage if you don't do something about it before using the truck again!
Give it a full tune up!
Old Nov 6, 2011 | 09:44 AM
pws's Avatar
pws
what would you recommend that i do should i put something in the fuel or maby put some oil and fuel mix in the fuel filter.thanks.
Old Nov 6, 2011 | 10:52 AM
IDIDieselJohn
Any diesel conditioner, but if a injector is sticking open, they might be tired, and it won't help much if any at all.
But just for the hell of it, get a new fuel filter, and fill it up with diesel conditioner, start the engine up for 20 seconds, then shut it off, and let it sit minimum an hour, or over night is even better, then start 'er back up, let it warm up, and go for a good hard ride! Drive it like you stole it!
Old Nov 6, 2011 | 01:59 PM
vfelix702's Avatar
vfelix702
X2 of diesel kleen in the filter and driving it like you stole it after sitting overnight!!!
Old Nov 6, 2011 | 02:23 PM
pws's Avatar
pws
thanks guys i will try that.
Old Nov 7, 2011 | 12:45 AM
Aune163rd's Avatar
Aune163rd
Also, if you need an IP and injectors....the injectors are fairly cheap, you might also wanna check to see what kind of pressure your IP is putting out..ii know the lift pump is a big one that screws with us...the 84 had its mech one from 1984 still working(I called the mechanic who rebuilt the 84) and the 83 has an electronic one that runs after the key turns on.
Old Nov 7, 2011 | 12:48 AM
Aune163rd's Avatar
Aune163rd
I know a reman'd IP(Injection Pump) is like ~400-500 $$, but they are good for 100k miles after replacement and timing.
Old Nov 7, 2011 | 09:42 PM
pws's Avatar
pws
so far so good i took her out today and all seems well so far but time will tell.i app, all the comments thanks.
Old Nov 7, 2011 | 10:08 PM
vfelix702's Avatar
vfelix702
@ PWS ----on your so far so good thing you got going right now does that mean you used diesel kleen??
Old Nov 7, 2011 | 10:30 PM
Aune163rd's Avatar
Aune163rd
I would hope so haha.
F250TruckR
Apr 30, 2009 03:07 AM
locknload223
Nov 21, 2008 04:29 PM
roadbike21
Mar 24, 2006 07:28 AM
truckertony
3.8 & 4.2L V6
Jan 22, 2004 10:38 PM
fordtruckinsml
Mar 31, 2003 09:31 PM
