1986 6.9L with WEIRD problem!?!?
Old Mar 24, 2006 | 01:25 AM
roadbike21's Avatar
roadbike21
I have a 1986 Ford F-250 with about 189K miles. The engine was running great until my stupid dad apparantly ran the truck out of oil. The engine still starts and sounds GREAT at idle, but when you hit the gas it begins to make an AWFUL noise towards the rear of the engine. I can put it in reverse and get on the gas hard and make it stop that noise, but then when you get on the gas again in neutral you get the loud knocking noise. What do you guys think the problem is?? Main bearings, crank shafts, bad injector, what??? I have removed the transmission to eliminate it and the engine still makes the loud noise towards the rear of the engine. thanks for your time
Old Mar 24, 2006 | 05:42 AM
bilder12's Avatar
bilder12
ran it out of lube oil? what type of noise is it? heavy noise is crank shaft related, double slap noise is connecting rod related, heavy ticking could be injectors or lifters.
Old Mar 24, 2006 | 07:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
is the oil pressure low?? if so, it probably spun a bearing
