harmonic balancer
Old Nov 5, 2011 | 07:19 PM
BIGskinny's Avatar
BIGskinny
thanks guys not so sad afterall lol...another question. does the smog pump need to be removed also?
Old Nov 5, 2011 | 09:14 PM
Encho's Avatar
Encho
The Southernmost Mod
Replaced if it isn't working right, don't just remove it because a couple of sensors are related to it, EGR and ECT if memory serves... If you remove it you will probably lose a couple of MPG and will gain nothing performance-wise.
Old Nov 5, 2011 | 10:09 PM
Kudofo's Avatar
Kudofo
305 with a breaker bar and you didn't break the bolt. What the hell is that bolt made out of!?
Glad you got it off though. Remember it might be embarrassing but if you didn't break anything you didn't waste money. You can go buy yourself a beer and forget all about it.
Old Nov 5, 2011 | 10:16 PM
BIGskinny's Avatar
BIGskinny
oh the bolts that hold the puller to the pulley were flexing and it was rented from advance auto costed me 107 so i didnt want break it but luckily i found the issue and got it off..finally got the timing cover cracked open and its not a very pretty sight ill say that much..let me see if i can figure out how to up load a pic or two
<a href="http://s178.photobucket.com/albums/w253/bigbubba1991/truck/?action=view&amp;current=fgege.jpg" target="_blank"><img src="http://i178.photobucket.com/albums/w253/bigbubba1991/truck/fgege.jpg" border="0" alt="Photobucket"></a>
<a href="http://s178.photobucket.com/albums/w253/bigbubba1991/truck/?action=view&amp;current=svfegrt.jpg" target="_blank"><img src="http://i178.photobucket.com/albums/w253/bigbubba1991/truck/svfegrt.jpg" border="0" alt="Photobucket"></a>
im not auto expert but i think its a little bit lose to timing chain..
Old Nov 6, 2011 | 04:17 AM
muscletruck7379's Avatar
muscletruck7379
looks like its getting there, I know that the old rule of thmb is no more than the width of the chain, but i'm not sure how much that would apply to a double roller. I think that 1/2" play is the most acceptable limit. but I would go ahead and replace it, simply for the fact that you already have it apart
but it looks like the engine has missed its fair share of oil changes (or has been using some horrible oil) along with leaking its fair amount... it is diiirty!
Old Nov 6, 2011 | 04:50 AM
Kudofo's Avatar
Kudofo
Just be carful cleaning up all that sludge... oil screens, pumps, and filters, hate all of sudden being maxed out with sludge.
I would replace the timing chain as its not really that expensive. Get a new water pump because your down there. Once its all put back together I would run some sea foam through that crank case and than change the oil.
Just do NOT put any load on your motor while your running the sea foam in the crankcase and make sure your motor is hot when you do it. Load + thinned oil in bearings = knocka knocka knocka.
Old Nov 6, 2011 | 04:52 AM
lew52's Avatar
lew52
Thats alot of slop , replace it , how does it look in the pan , if there is sludge in there you might want to remove it and clean the pick up tube and screen while your at it.....Lew
Old Nov 6, 2011 | 09:04 AM
BIGskinny's Avatar
BIGskinny
yeah its rought looking. . could of used better oil changes in its life thats forsure! i was in the process of tryin to hunt down the leak but no idea where its coming from. more then likely i will go ahead and drop the pan and clean it since im already that far, and im sure some water has ran down in there and chunks and sludge willl drop..so its best to go ahead and drop it IMO..thanks for the tips and points guys its helpful. ill throw some more pics up this afternoon.
Old Nov 6, 2011 | 10:31 PM
BIGskinny's Avatar
BIGskinny
<a href="http://s178.photobucket.com/albums/w253/bigbubba1991/truck/?action=view&amp;current=timingcover.jpg" target="_blank"><img src="http://i178.photobucket.com/albums/w253/bigbubba1991/truck/timingcover.jpg" border="0" alt="Photobucket"></a>
pretty bad sludge on the cover...scraped and clean it all out.
<a href="http://s178.photobucket.com/albums/w253/bigbubba1991/truck/?action=view&amp;current=hole.jpg" target="_blank"><img src="http://i178.photobucket.com/albums/w253/bigbubba1991/truck/hole.jpg" border="0" alt="Photobucket"></a>
found a hole in the timing cover while i was cleaning it..mayby the coause of all the oil leaking. not sure.
<a href="http://s178.photobucket.com/albums/w253/bigbubba1991/truck/?action=view&amp;current=oldoff.jpg" target="_blank"><img src="http://i178.photobucket.com/albums/w253/bigbubba1991/truck/oldoff.jpg" border="0" alt="Photobucket"></a>
got the old one off finally.
<a href="http://s178.photobucket.com/albums/w253/bigbubba1991/truck/?action=view&amp;current=newchain.jpg" target="_blank"><img src="http://i178.photobucket.com/albums/w253/bigbubba1991/truck/newchain.jpg" border="0" alt="Photobucket"></a>
<a href="http://s178.photobucket.com/albums/w253/bigbubba1991/truck/?action=view&amp;current=newchainon.jpg" target="_blank"><img src="http://i178.photobucket.com/albums/w253/bigbubba1991/truck/newchainon.jpg" border="0" alt="Photobucket"></a>
yes i had them lined up correctly, but tightning the camshaft gear it turned a bit
Old Nov 7, 2011 | 07:58 AM
muscletruck7379
best advice i have for finding oil leaks is to take it down and completely wash the engine off, drive some and then look for the source.
Old Nov 8, 2011 | 10:57 PM
BIGskinny's Avatar
BIGskinny
I'm goin to clean it up best I can while it's this far down. Been put on hold for a few days. I tweaked my back the other day and can barely get out of bed moreless lean over the radiator support.
Old Nov 8, 2011 | 11:15 PM
rla2005's Avatar
rla2005
Slacker
In all honesty, get well soon!
Old Nov 9, 2011 | 09:17 AM
  #28
BIGskinny's Avatar
BIGskinny
Originally Posted by rla2005
Slacker
lol thanks man. it hurts like hell but what dont kill ya makes ya stronger, its killin me seein the ol girls heart ripped apart for so long lol. im really thinking about toughing it out and gettin it done today.
Old Nov 9, 2011 | 10:57 PM
  #29
BIGskinny's Avatar
BIGskinny
trucks all back together, running like A CHAMP. hopfully ill see a lil bit of an increase in mpg. thanks for the tips and points guys!
Gigemags05
26
Nov 19, 2014 08:37 PM
quakerj
Aug 21, 2013 07:08 PM
dmueller71
Dec 18, 2010 10:49 AM
pvatki
1983 - 2012 Ranger & B-Series
Sep 24, 2009 11:21 PM
ExcellentRed
Aug 1, 2004 04:52 AM
