Would a truck start at ~15 degrees with 4 working glow plugs?
Mine would not start at 35f with the passenger side GP's not working and 1 bad and 1 weak injector on the same side. I'm sure the compression is a little down on mine with 355,000 miles on it, so yours may do better.
Ford says these trucks will start without external aid in temps down to -10 degrees. Of course this assumes a properly working glow plug system and anti gel additive in the fuel.
Any lower and the block heater needs to be plugged in or warmed up via some other method.
Based on that info, I would not expect the engine to fire in -15 temps with only 4 working glow plugs.
With good 850+CCA batteries, 5-40 synthetic oil, a good GP relay and all GP's working, I have started my truck at -15 degrees...BUT the OP asked for ~15 degrees (that little squiggly line means "about", not "minus"). I would guess you would have a heck of a time getting it to fire with four dead GP's at 15 degrees.
