Fuel Leak
Old Oct 29, 2013 | 06:31 PM
Old Duke 6's Avatar
Old Duke 6
Fuel Leak
Greetings everybody, I have a 1999 Ford F350 7.3 super duty, lariat, crew cab, four-wheel-drive. It's leaking fuel, from the, driver side head. The fuel leak is coming from a brass, or copper, nut, just above the driver side exhaust manifold up pipe. It's a prominent leak, and I can't seem to trace it. This "plug" is just right next to the furthest freeze plug on the driver side rear of the block.
I've already replaced the Fuel Bowl Drain valve Orings, and the valley is bone dry.
If anyone has encountered this problem, for the love of god!! HELP!! Its blowing through a 1/4 tank of diesel in 38 miles!
It runs fine, drives fine, but i have noticed that once the system is priming it leaks, then stops.. once started... It pours... I'm lost..
Anyone with pictures?
Old Nov 2, 2013 | 09:56 PM
Old Duke 6's Avatar
Old Duke 6
So, I ordered a boro scope to get a better view of the leak, which is coming from the driver side head.
There is a silver bolt, which a 1/4 in drive rachet will fit. It's just next to the freeze plug back there on the driver side of the head.
I took a few pics of the problem.
How do I post them?
Old Nov 2, 2013 | 10:05 PM
tappit01's Avatar
tappit01
upload to photo bucket, then copy and paste the link.
Old Nov 2, 2013 | 10:52 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I need a picture.. I dont know what youre talking about. I cant think of anything back there fuel related.
Old Nov 2, 2013 | 11:05 PM
AllaboutMPG's Avatar
AllaboutMPG
When you say a 1/4 in rachet, did you mean it has a 1/4 square head. There is a plug on the back end of the drivers head that is the fuel rail plug. It's just outboard of the turbo. If that's it then it's pipe thread and should quit leaking if you tighten it. If that's not it then try to post a pic.
Old Nov 3, 2013 | 04:42 AM
Old Duke 6's Avatar
Old Duke 6
AllaboutMPG, yes. Bolt with a square hole. I tried to tighten it, and it still leaks, if thats even where its coming from. I'll post pics later today, as of right now... need some winks..
Old Nov 3, 2013 | 05:03 AM
Old Duke 6's Avatar
Old Duke 6
Ford 7.3L Power Stroke Diesel Injector Removal and Installation: Engine Builder
Second picture in that link.
Is there a Oring on this thing?
Old Nov 3, 2013 | 09:13 AM
AllaboutMPG
I may have misled you. The one I was talking about is on top of the head. I believe it is a test port and has a male square head not a female square head. We'll have to wait on one of the guys who has more rebuild experience to answer this one.
Old Nov 3, 2013 | 10:46 AM
milehi_350's Avatar
milehi_350
Isn't that a banjo bolt. Their are four banjo bolts, one at each end of both heads.? Their are orings on these. Sounds like yours has failed.
Old Nov 3, 2013 | 11:03 AM
Sieggy's Avatar
Sieggy
I had a fuel leak as well a while ago on my 2000 Excursion 7.3 and found it to be coming from the fuel bowl. After rebuilding it with new seals and o-rings the fuel leak stopped. Get the blue o'rings as they work better with the low sulfur fuels....
Old Nov 4, 2013 | 05:12 AM
Old Duke 6's Avatar
Old Duke 6
Sieggy, I've already done that.. less than 1 week ago. 2 times.. Because at first I didn't use Viton Type "B" Orings.. And the
valley between the heads.. BONE DRY.
Old Nov 6, 2013 | 04:41 PM
Old Duke 6's Avatar
Old Duke 6
I'm still perplexed as to the issue with this.. I haven't found any other information referencing this.
It is labeled in the link I posted as a "Head Fuel Drain.." Anyone else know more?
I'm afraid to remove it, in the event that something breaks, or component pops out that I won't be able to reinstall, given the tight space.
Old Nov 6, 2013 | 05:01 PM
milehi_350's Avatar
milehi_350
It's got to be your banjo bolt. Bob has orings.http://http://www.dieselorings.com/1999-2003-ford-7-3l/fuel-system-parts-filters/15-018-fuel-end-plug-banjo-bolt-o-rings.html
Richard Templeton
Feb 22, 2017 08:47 PM
04Terminator
Nov 5, 2011 08:38 PM
bulletpruf
25
Aug 2, 2011 04:13 PM
ghig1967
Dec 11, 2009 06:23 PM
rgconway
Dec 20, 2008 03:44 PM
