I wonder if they used the power to the horn to run whatever it is that the button operates.. Does it by chance have an aftermarket speedo? My brother just got a 75 with some special speedometer that has a little red button on the steering column to "set the speedometer" although i havent a clue as to how it works or why you would stick that speedometer in there.
Told you it is the Batphone! The wire to the solenoid gets power for the phone and the one to the horn is the ringer. Seriously sounds like someone may have wired the horn through the switch.
I think that joke was funny like a dozen posts and as many days ago... really just beating a dead horse and neither being helpful nor amusing.
It's a good thing I wake up every morning seeking only your approval from life. I would feel like such a waste of breath if I didn't have you to comment on my choices. Thank you so very much.
And yet you feel like you have to make fun of someone who posts a question about a button on his steering wheel? Hello, kettle, I am pot and you are black. tard
it sounds like a horn button, on one of my trucks i have a toggle switch mounted lower part of dash for the horn. i would like to say thanks to the po for deciding the steering column didnt need all those wires. have you tried pushing the button?
They were making fun of a dash mounted red button with wires running to the top of the transmission and then running toward the drive shaft
Lighten up, life's too short not to have a little fun.
I left this forum for a year because we had some folks that thought everything was serious and had to be called be exact Ford factory name and berated every new poster for any tiny mistake they made. Thank God these people moved on or were banned.
All the folks on this forum are good about helping each other when there is enough info to do so.
Zehcnasca should not be offended, we were all waiting for pics and more info to give him the help he needs.....................Bad Bart.
