All I need is a pinout of where the wires are supposed to go. This project isn't any harder then repinning a 94-95 mustang to take an a9l from a foxbody or adding a massair ecu to an 87-88 mustang
What the problem i have is that the diagram of the pinouts don't show clearly where the extra injectors or the maf wires go.
I have a 90 e4od truck. What column shows where the maf wires go for my application. Is it the 94-95 column I look at....because that's the only column that shows 8injector outputs and maf wires. How about you assist in helping instead of saying I Need more research. This project is cake if I had a diagram.
For a 1990 Speed Density truck like yours you would reference the 5th column over from the left, it's labeled "87-95 302/351 Truck/Van/Bronco Speed Density". Now that you are wanting to use a later model truck PCm that supports MAF you need to reference the 6th column over from the left, it's labeled "94-95 302/351 Truck/Van/Bronco Mass Air". Columns 8 and 9 from the left are the additional wires needed for Speed Density/MAF (respectively) trucks with a E4OD transmission.
As far as diagrams go here is one for 86-95 302/351 Speed Density trucks: stolen from FordFuelInjection.com
Here is one for 94-95 302/351 Mass Air trucks: stolen from FordFuelInjection.com
Thanks. I appreciate the clarification. I had asked in post 7 if I copied the 94-95 diagram or not.
Having the forum definately helps.
My contact I use to have at the dealership retired and I can't get diagrams anymore. I use to have tons of printouts until I moved last year.
Only downfall to using a 2wd ECU (with an electronic transmission) on a 4wd rig is that you wont be able to utilize 4-low.
I know I am digging up an old thread but had to ask a question. Is that due to lack of programming or hardware. I am planning a MAF conversion in a month or so and came across an AKC0 for a wicked deal that I couldn't pass up and we all know how hard E4OD compatible PCMS are to find but found that out after the fact
That's because the computer is not controlling the transmission.
When a computer controlled trans like the E4OD is in the mix and the computer depends on vehicle speed input for shift points, if it doesn't know about the presence of a T-case it gets the trans shift points all F'd up when that t-case is in 4-low.
