Front Spring Question
Old Nov 3, 2011 | 09:17 AM
throwdown's Avatar
throwdown
I am going to change the front springs on my 01, F350, 4X4. I can get the X codes from Ford cheaper than aftermarket stuff.
They need new bushings and have about 300k on them. I think this will level the front where I want it and fix the sag.
My question is...is there anything I need to do other than just swap them out. I will be changing u-bolts as well. Track bar? Drag link?
Any help is appreciated. Thanks
Old Nov 3, 2011 | 09:50 AM
Crewcab Turbo's Avatar
Crewcab Turbo
When you do your x code swap could you post a measurement from the top of the axle to the bottom of the frame? In the future I may want to go down to x codes (depending on there height) from my 4" lift that came with my truck. Thanks
Old Nov 3, 2011 | 11:51 AM
throwdown's Avatar
throwdown
I' ll do that. From what I gather from other posts, I should gain about an inch and a half from my stock springs.
We shall see.
Old Nov 7, 2011 | 09:57 AM
throwdown's Avatar
throwdown
Well CrewCab Turbo, I guess no one wants to give up any info. The only response to my thread was from you. I'll let you know when I do the swap.
Old Nov 7, 2011 | 04:03 PM
HH60FE's Avatar
HH60FE
Are you refering to any other maintenance needin' done? No. Swapping the springs should be all you need. A front end alignment might be in order though.
Old Nov 7, 2011 | 05:14 PM
throwdown's Avatar
throwdown
Thanks for the response. I guess it's not a hot topic right now.
I figured an alignment would be in order. I always align when I put new rubber on anyway and it looks close enough for me. New springs new tires. Good start.
Thanks for the info.
Old Nov 7, 2011 | 05:29 PM
Crewcab Turbo
Throwdown, how much space is between the bottom of your frame to the top of the axle tube with your stock setup? Mine is 13" and I'm not sure but it may be a 4" lift? Mine has a drop trackbar bracket but I believe you won't need one. You should be fine with the springs and mabe an alignment.
Old Nov 7, 2011 | 07:07 PM
throwdown's Avatar
throwdown
I can measure that for you tomorrow if you like, however, there is 375k worth of sag in the springs and it may not be quite what you wan to know.
I have had many lifted trucks and if you have a drop track bar mount, I would say it is at least 4" lift.
My original question was because I have never replaced a spring with a stock spring that has more arch. I was not sure if I would have to change anything like I would with a lift.
Anyway, I will let you know what it measures now and after I put the X codes in.
Old Nov 8, 2011 | 01:24 PM
JOB1963's Avatar
JOB1963
Hey throwdown, I'm trying to learn about the front end suspension(stock) on my 2003 F350SC/LB, I'm hearing these codes thrown around and wondering what are they? I posted a question on here a few days ago about front suspension and someone asked me "what code springs are" I hear you saying X code. Can you tell me what it means? Newbie here tryin to figure somethings out. I'd really appreciate it.
Thanks
John
Old Nov 8, 2011 | 01:33 PM
Crewcab Turbo
Southside of Chicago? Didn't think there was anyone in this area I'm just a bit more west. The codes are the letter of the front or rear springs that tells you the weight rating. Look at your door sticker it will have 2 letters one for front and one for rear. I believe the x is a f450 truck fronts and also the snow/camper package on 250/350 trucks I believe. The truck sits about 1.5 inches higher with x codes.
Old Nov 8, 2011 | 04:13 PM
throwdown's Avatar
throwdown
Crewcab....I measured from the top of the spring to the bottom of the frame right above the axle tube. My truck has stock springs right now (saggy I'm sure). There is about six inches.
I will post the new measurement when I get the X-codes in.
Job1963...I think Crewcab answered the question as good as I could.
We will all know more when I get the X-codes in.
Then I can go to work on the back. I have had this truck since it was new and it has always seemed to be lower on the drivers rear. I have changed countless springs from breakage.
I think it's time for some Ride -Rite action.
Stay tuned................
Old Nov 9, 2011 | 09:12 AM
JOB1963's Avatar
JOB1963
Ya there are still a few of us here on the southside, hope to be outta here soon, but in the meantime gotta work with what I got. Please see the door sticker and point me in the right direction. I'm not seeing what you described above. Thanks
John
Old Nov 9, 2011 | 09:26 AM
Crewcab Turbo
Your fronts are V and rears are S on your sticker. Its under SPR .For an example mine is V for front and A for rear. Someone here has a listing they posted from the ford manual that details the codes and applications and weight ratings.
Old Nov 9, 2011 | 09:30 AM
JOB1963's Avatar
JOB1963
10-4 Thanks, I'm searching FTE for this info next.
Old Nov 9, 2011 | 02:19 PM
akorcovelos's Avatar
akorcovelos
This may help with some of your questions;
www.ford-trucks.com/forums/1031937-how-to-id-x-code-springs.html
SATX210
Jul 20, 2018 12:58 PM
Haulinbass02
Aug 9, 2017 12:59 PM
2002exPSD
Jun 25, 2012 07:51 PM
jeeplj8
Mar 23, 2012 10:52 AM
MoreLoveThanMoney
Mar 24, 2011 12:53 PM
