Help installing a transmission temp gauge
Old Nov 3, 2011 | 12:25 AM
90pioneer's Avatar
90pioneer
I bought a B&M transmission temp gauge today and want to put it in my truck, a 97 F250HD with the E40D trans.
I want to take the temp reading from the pan. Is there a port the sensor will just plug into?
Also the gauge is lighted. Where do I find the wire to tie into so it will work with my other dash lights?
Old Nov 3, 2011 | 12:42 AM
86F150302's Avatar
86F150302
Do a search. I've posted pics before. You can tap into the illumination wire for the gauges. Search will also give you info on that.
Old Nov 3, 2011 | 10:58 AM
Kemicalburns's Avatar
Kemicalburns
there is a spot on the side of the E4OD for a temp gauge. i believe its just above the pan on the drivers side but not 100% on that location.
Old Nov 3, 2011 | 02:28 PM
90pioneer's Avatar
90pioneer
I found the pic you posted of where the sending unit mounts but I still dont know where the illumination wire for the gauges is and what wire I can tap power from??
Thanks!
Old Nov 3, 2011 | 02:34 PM
kentuckyredneck's Avatar
kentuckyredneck
Easiest wire to find to tap into would probably be the light in your ashtray. It dims with the rest of them.
BGF100
Nov 13, 2015 08:14 PM
slinginsaws
Oct 28, 2014 04:12 PM
daltonhawk
Jul 4, 2013 12:18 AM
frankyford
Aug 2, 2009 03:17 PM
alirojam1
1978 - 1996 Big Bronco
Dec 14, 2004 01:30 PM
