Temp gauge isn't working now
Old Aug 2, 2009 | 10:40 AM
frankyford's Avatar
frankyford
The temp gauge on my 95 F-150 302 auto is not working. I replced the ECT a couple of months ago, it's not throwing a code for that anyway. If I remember correctly I tightened it as far I could without stripping it. I had the voltage tested yesterday and it came back good. Any other ideas?
Old Aug 2, 2009 | 11:13 AM
Volvo92906's Avatar
Volvo92906
In my experience you have a problem. You have electrical gauges. The actual gauge can be bad.. I assume? I was always taught to hook up a mechanical gauge to check and see if you are indeed getting a reading. But, if your sensor is good you should hook it up and follow it to behind the dash where it runs to, test it there for current.
Old Aug 2, 2009 | 03:17 PM
subford's Avatar
subford
The ECT sensor has nothing to do with the gauge.
You need to look at your temp sender with one wire on it behind the distributor on the drivers side.
It screws into the lower intake manifold.
87 XLT's Avatar
87 XLT
The ECT is 2 wires the temp gauge sender is a single wire. Two different animals.
Try this very simple test pull the wire off of the temp gauge sender, ground it to the block & turn the key one click. The gauge should read full hot.
