Running temp
Old Nov 2, 2011 | 09:25 PM
FXcursion3's Avatar
FXcursion3
Running temp
Hey all, new to the forum. I have a 2000 Excursion. V10, 4x4, 6" Lift and 325/60/18 Terra Grapplers on it. I haven't really paid attention to it because of it NOT being cold in SC until recently. But do excursions run a bit cooler then most Suvs? The temp gauge shows a bit under half. Not sure if i should replace the thermostat, but it seems to be blowing warm air on my frozen toes in the morning. Anyway, just thought I'd ask around! Thanks!
Love the site by the way!
Old Nov 2, 2011 | 09:51 PM
trucktech's Avatar
trucktech
mine is also a 00 v10 and to me it seems like it about 1/2 to 2/3 the way where the middle of normal should be. i have changed the stat and no change. it has been down into the 20s and havent had a problem i am looking in to checking my fan clutch and make sure it isnt running all the time.
Old Nov 2, 2011 | 10:00 PM
labman1014's Avatar
labman1014
If I were y'all, I would get something more accurate then the dash gauge. I have a scan gauge 2. It reads the actually temp. Mine reads from 170*-185*.
Old Nov 2, 2011 | 11:15 PM
gr8scott72's Avatar
gr8scott72
Bingo!
The dummy gauge on the dash doesn't give you an accurate indication of the actual temp. It will basically just let you know if it is warming up and if it overheats.
NM33013
May 1, 2018 01:35 AM
BIGskinny
Aug 20, 2011 05:50 AM
smokin_6.0
Jun 16, 2007 08:24 PM
robdaniels
Modular V10 (6.8l)
Nov 26, 2003 09:00 PM
JoeN
1978 - 1996 Big Bronco
Jun 12, 2001 03:01 PM
