1978 - 1996 Big Bronco
Cooling question
Old Jun 9, 2001 | 08:59 PM
JoeN's Avatar
JoeN
Cooling question
Hi All,
My first post, great forum.
I have an 87 5.0,stock, recently my temp gauge is showing the engine running just above the cold line. Of course the raidator and lines are all hot. Replaced the thermostat,temp sensor so far. Might be the gauge but it is working. Moves freely, shows temp. rising to certain point then stops. Live in South FL temp today 101 with heat index so... Any ideas where to start.
Thanks
Joe
Old Jun 10, 2001 | 10:52 PM
lastbronco's Avatar
lastbronco
Cooling question
Joe, I had a 87F-150 5.8L when it was just 2 years old. My temp gauge always ran to the cooler side as you mentioned. I always kept her tip top shape(hoses,thermostat,fresh coolant,etc.) check with your mechanic about thermostat temp. All in All I'd say your gauge is right on.
Mike (lastbronco)
Happy Motoring
Old Jun 11, 2001 | 01:29 PM
fast_eddy's Avatar
fast_eddy
Cooling question
My '96 with the 5.8 does the same thing, as does my buddies '92. I thought there may be a problem, but my mechanic says that's just the way they run. Doesn't seem to be a problem...
Old Jun 12, 2001 | 03:01 PM
gator2000's Avatar
gator2000
Cooling question
1950FordF3
Aug 13, 2016 10:48 AM
kincfu
Jan 31, 2016 05:56 AM
bandlgeorge
Nov 30, 2015 02:59 PM
cabinman
Jun 30, 2015 08:36 PM
stainlessstroker95
Jun 17, 2011 08:18 AM
