These engines are known for reliability and longevity not HP!!
Oh theyre starting to get known. Ill bet theres at least 20 hi-po IDI build threads that have started in the last 6 months. Just because nobodys done it yet, doesnt mean it cant happen. NMB2 is the proof.
S- series, would that be the IDI's in the obs supderdutys?? I never knew there where any different model of engines, just 6.9 and 7.3 with all the same stuff.
last time i check cold air allows for more power. correct me if i am wrong. i am almost done with my wannabe hypermax cowl intake in hopes of getting more cold air. I will post pics of my set up monday.
My cold air intake dropped my egt 200* under full load.
The s series IH trucks have a cold air intake already thru the hood /cowl.
You both have turbos'. He does not. The way I read it he is talking about installing a cold air intake on a NA IDI. With a turbo you generate much more than enough heat to warrant a cold air intake, but without one, as a performance mod, you would not see similar results IMHO.
Better to either bite the bullet and get a turbo or concentrate on other mods like exaust or electric fans ect. is all I am saying. BTW I still run a fan clutch, I know it works, I can see the results when I am towing my fifth wheel. Not endorsing electric fans, just putting it out there because it will increase available horsepower to the rear wheels which is what he was asking.
Mac.
Reason: typos
