1990 7.3 fuel problem
Old Nov 1, 2011 | 09:01 PM
mikey11211's Avatar
mikey11211
hi all..i have a 1990 f350..7.3 non turbo..its losing its prime after sitting for about an hour. ive replaced the manual fuel pump and it was good for about 2 weeks..now i have to hit it with ether every morning to get it started. i just installed an electric fuel pump between the tank and the manual pump...no good. im guessing the problem is between the manual pump to the fuel filter? maybe a defective manual pump? when i bleed it i get alot or air out before fuel starts coming out...on the other hand when i cut the metal fuleline to instal the electric pump no fuel came out. now what ? any help would be greatly appreciated ..thanks
mike in nj
Old Nov 1, 2011 | 09:35 PM
hairyboxnoogle's Avatar
hairyboxnoogle
sounds like youre mechanical pump might have a bad diaphragm and letting air in, or you have a leak somewhere before the pump sucking air in.
Old Nov 1, 2011 | 09:41 PM
mikey11211's Avatar
mikey11211
thanks..should i replace the manual pump? sound like a faulty pump? is the diaphragm in the pump? i know nothing when it comes to that. thanks again
BRay09
Sep 22, 2015 07:19 AM
Cdn Eh
Aug 14, 2015 09:35 PM
schmity
Mar 2, 2007 03:41 PM
jonjayjabroni
Aug 13, 2005 03:44 PM
