Allright here is the low down..... I just replaced my front seal, pump o-ring and installed a transgo shift kit and after getting everything back together the truck started right up with 12-13 quarts of trans fluid i put the truck in reverse and it backed right off the ramps.... now here is the fun part.... the truck ONLY has reverse.
all of the linkage moves freely and park works but only when the truck is off but otherwise P R N D 2 1 all go backwards WTF!! Does anybody have any thoughts? It went forward before i started it just leaked alittle now all backwards
