Whining p/s pump upgrade
Old Oct 29, 2011 | 02:59 PM
F-250 restorer's Avatar
F-250 restorer
I was tired of the whining oem p/s unit, even though mine was newly rebuilt (A.Zone). In parking lots it didn't seem to give enough power as my steering faded when hard worked. When I did my hydroboost install I was told to go with a Saginaw pump for more power, and found one made to bolt right up to the oem bracket. But it doesn't supply enough power, and I'd like to do away with the 'wing' look of the monstrous oem bracket that sticks out like 18" from the block. I've noticed that econoline vans came with the 'canned ham' type Sag. pumps that everyone wants and raves about. So I pulled one of the brackets that can work with or w/o air. The trick, I see, depends on which groove on the dampener you want to use for the p/s belt; if you are not using air, and need to use the third groove, the one farthest from the block (I use the two closest the block for dual belt 130 amp alt pulley), then you need to order the Sag. pump for a 77 econoline w/o air. If you want to use the groove closest the block, then order the pump for an eighties Econoline with a 300, with a/c. The diff. is in the length of the pump snout. The bracket too is an improvement as it sits much tighter to the block. Ford pumps are notorious for whining!
A bit greasy, but nothing a solvent bath won't help. They seem to be pretty rare at the j/y too. In the coming years our parts are going to get harder to find, and more costly, as the supply of used items shrinks.
In this photo you can see how the oem bracket, circa 1978, hangs way out to the side, creating what I call my 'p/s wing'.
Old Oct 29, 2011 | 04:57 PM
hgb4x4's Avatar
hgb4x4
just lost my P/S in my '86 and yes it wined alot lol.... gonna do somit next sat but for now the arm strong action sux with big tires lol
Old Oct 29, 2011 | 08:15 PM
JimsRebel's Avatar
JimsRebel
my power steering belt is in the middle V groove
1st (Engine side) is ALT
2nd is power steering pump
3rd (next to the rad) is A/C
Old Oct 29, 2011 | 08:44 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
I found the same bracket at the yard and the new pump works like a charm. The steering is almost too easy.
And it does look so much tidier than the old stock bracket. You should be very happy.
Old Oct 30, 2011 | 11:54 AM
F-250 restorer
BVA:
I see your pump has the long snout so you can utilize the outside grove on the v.dampener. Do you remember what year that pump was for? a/c or w/o a/c?
I'm thinking of searching for the old 70's 'canned ham' reservoir with dual return lines. It should work on any of the Sag. models. That way I won't have to use a T in my lines.
Old Oct 30, 2011 | 01:25 PM
BaronVonAutomatc
I think I just got a pump for an '86 E150 with a/c (my Bronco is an '86 with A/C). It has a three groove balancer and the p/s pump runs in the middle groove - A/C in front and alternator closest to the block.
Old Oct 31, 2011 | 10:30 AM
AbandonedBronco's Avatar
AbandonedBronco
But my whining steering pump is how my wife knows I'm getting home from work!
She can hear it two blocks away.
Honestly though, I want to follow suit in this upgrade. I'm still curious what my engine sounds like.
Benningtonr
Ford Truck Parts for Sale
Feb 16, 2018 08:26 AM
jerryst
Aug 8, 2016 11:05 AM
ecard
Apr 12, 2015 04:42 PM
plow/truck
16
Dec 30, 2011 08:40 PM
flip4eva83
Nov 14, 2011 10:38 AM
