Starter removal
Old Oct 26, 2011 | 06:57 PM
sailorjohn's Avatar
sailorjohn
Starter removal
I can see it but can't get to it.
Is there any trick/tool to get to the top bolt on my starter so I can remove it?
Old Oct 26, 2011 | 07:35 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
swivel and extensions and some French. Haha just make sure when installing it you get all them tight. Could cause starting issues.
Old Oct 26, 2011 | 07:43 PM
riverrat41's Avatar
riverrat41
I use a stubby ratchet wrench.
Old Oct 26, 2011 | 09:14 PM
Dean88's Avatar
Dean88
Last one I did I used a four foot wobble extension and did it standing by the bumper.
Old Oct 26, 2011 | 09:19 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
When installing the new one I would use some red locktite on the threads to keep them from backing out by themselfs.
Old Oct 26, 2011 | 09:35 PM
Ponyboychris's Avatar
Ponyboychris
John has an E350 van. Are the starters in that chassis different to get to verses the trucks?
Old Oct 27, 2011 | 05:48 AM
sailorjohn's Avatar
sailorjohn
Thank you for noticing the van and possible difference Ponyboy. I don't think that there is any way I could have used a 4 foot extension to get to that top bolt but I will check the next time I am under there. I did get the top bolt off (and didn't need to use any "french" - but it was a helpful suggestion). I used a 3/8 swivel and a 3" extension when I put it back on I'll use a 4" or 6" extension - not sure that there is room for the 6".
I won't be using red lock-tight. Red lock-tight is for permanent usage, blue is somewhat removable but there didn't seem to be any problem with the bolts being loose. As a machinist I know that generally if the bolt and threaded hole are good and the bolt/screw is tightened to the proper torque range then it should hold (actually they are screws that hold our starters on - mine happens to have two hex head screws and a stud with a nut). Problems arise when we over tighten or use poor quality,damaged or dirty screws. Then we can get problems like, the treads can stretch and lose their holding power.
thegreatgate
2004 - 2008 F150
Dec 22, 2022 08:47 AM
L9000 Fire Truck
Large Truck
Apr 30, 2017 07:44 PM
ithaca1230
Dec 30, 2016 09:51 PM
Daniel_3168
Feb 6, 2016 12:59 PM
kingcoda
Sep 5, 2004 09:43 AM
