Had a constant clunking. I know my end link bushings are shot(energy suspension master kit ordered) and figured that was it. Was under the truck yesterday and noticed I had virtually no clearence between the right end link and leaf spring. looked closer and the two have been rubbing. The left one has much less bend in it than the right but the right doesn't look like it has been hit or compressed(mount is not bent). I don't have another to compare it too or enough SD expirience to know. Does it look bent more than it should be to you?? End LInk :: endlinkrt2.jpg picture by artjp - Photobucket
I was able to slide the sway bar to the left and create enough clearence to stop the rub.
