Window help
Old Oct 25, 2011 | 02:07 PM
xc4jokestomper's Avatar
xc4jokestomper
Window help
On the truck in my sig my passanger side window is coming off of track or something. When i push the button for it to go up all you hear is the motor working but it hardly ever goes up. Also sometimes when i push the button for it to go up it will fall down some.
What is most likely the cause of this and how would i fix it?
Old Oct 25, 2011 | 04:32 PM
nstueve's Avatar
nstueve
might be a gear inside the door... Just taking a shot in the dark since I am old school and have manual crank windows...
I'd take the door pannel off and get in there, and have a root around to find the problem.
Old Oct 25, 2011 | 05:35 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The three plastic buttons that hold the gear inside the regulator wear out.
This pic is from JBG, the part is $12.
Window Motor Gear Repair Kit
Old Oct 25, 2011 | 05:36 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ooops, double post.
The new forum is FUBAR for me...
Old Oct 25, 2011 | 05:40 PM
White 97 xlt's Avatar
White 97 xlt
You nailed that one!!!!!
Old Oct 25, 2011 | 05:47 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Some people say you can use small (5/16"?) nuts to replace these plastic bushings, but I have never tried it...
Old Oct 25, 2011 | 06:22 PM
White 97 xlt
I've heard that also, but with my luck I will stick to the plastic parts, if I were to try to use the 5/16 nuts something would hang up and it would cost me a fortune to fix rather than shear the plastic..
Some things sure do need upgrading but I believe a power window needs the "plastic fuse".
Old Oct 25, 2011 | 09:19 PM
xc4jokestomper
Thanks guys! I appreciate it alot! Ill take a look tomorrow.
This is kind of off subject but what size is the lights that fit in the door panel right there? Id like to change those while im in there
Old Oct 25, 2011 | 09:35 PM
White 97 xlt
Mine uses a #912 for the courtesy lamp in the door.....
Old Oct 25, 2011 | 11:06 PM
86F150302's Avatar
86F150302
Winner! Sorry cant rep you....
Door panel light is 916 but 194 also works.
Old Oct 25, 2011 | 11:18 PM
Encho's Avatar
Encho
The Southernmost Mod
I've had the nuts in there for... 7 years now? they will work fine, that the door's electric motor out, then get to the gear in the lower half and replace the plastic button wih the nuts. To get to the three screws holding the motor in place you might need to do some drilling if the motor has never been serviced.
Old Oct 26, 2011 | 06:52 AM
xc4jokestomper
What might i have to drill?
Old Oct 26, 2011 | 08:39 AM
SideWinder4.9l's Avatar
SideWinder4.9l
I got him for ya!
Old Oct 26, 2011 | 11:17 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
1/2" holes, the three dimples over the motor...
Then you can block the window and remove the motor without taking the whole mess out.
cjben
Nov 26, 2018 03:31 PM
benHaskett
Escape & Escape Hybrid
Oct 2, 2015 10:04 PM
Sw1tchfoot
Oct 1, 2011 07:40 PM
jonathandennell
Mar 13, 2007 01:41 PM
John_1953
Jul 4, 2005 09:19 PM
