Another leaf spring thread
Old Oct 25, 2011 | 10:46 AM
TexasDiesel97's Avatar
TexasDiesel97
Was reading a thread started by RRranch about new leaf springs, now i wanted to know if any one has installed a set of 43-498HD's (three leaf set) on their 250 4x4. I have the 43-498 two leaf pack on my truck and i still only have at best a couple of inches clearance between the leaf spring and the bumpstop. Mainly wondering if there ae any ill affects from going this route. on a 250, since i've read that the leaf springs twist a little cause of the ttb set up.
Old Oct 25, 2011 | 12:22 PM
pjwoolw's Avatar
pjwoolw
Unless your running a heavy front bumper / winch or something along those lines the three leaf spring isn't worth the trouble. You would need a drop bracket for the D50 to get it aligned. But if you have enough weight to allow a decent alignment I would go that route. If you have two inches to the stop thats pretty normal.
Old Oct 25, 2011 | 01:45 PM
TexasDiesel97
Would the three leaf pack really lift it that much? Another question would there be any difference between the HD springs and say adding a add-a-leaf to the springs I have? In the end I want to level out the truck and have a little more wheel travel, the heavy bumper o have makes it bottom out in some rough roads.
octaneforce
May 4, 2010 09:50 PM
zstyle01
May 22, 2007 09:44 PM
Narwhal
Dec 28, 2005 06:56 AM
1952
Oct 13, 2003 02:31 AM
td351w
Jun 30, 2002 10:40 AM
