Spring sag
Old Dec 26, 2005 | 09:09 AM
Narwhal's Avatar
Narwhal
Spring sag
The continuing quest for a level-sitting truck.
Elvis had a decided left lean, to the extent that the leaf springs were only 1/2" off the spring bumper. Had both sides rearched, installed and they looked very good, about 4.5" of clearance between the spring bumper and the leaf spring pack.
Two weeks later, Elvis is leaning left again. Right side is at about 4" clearance and the left side is down to about 2.5" clearance.
The leaf spring packs have all their original leaves. I did have to grind some rust and matchbook cover thickness pits out when repainting.
1. Are the springs shot and need to be replaced, not rearched? Which leaves are most likely to be bad? Who would have the replacements?
2. Are there later model springs that I could use essentially without modification on the front of this 1953 F100? A junkyard solution is OK with me as I'm on a budget.
-Scott
Elvis - '53 Ford F100 with Mercury 254
Old Dec 26, 2005 | 01:05 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
I don't remember did you already swap springs between the left and right packs to try and level out the sag?
Old Dec 26, 2005 | 01:53 PM
Narwhal's Avatar
Narwhal
No, but that's a good idea.
-Scott
Old Dec 26, 2005 | 03:03 PM
AXracer's Avatar
AXracer
shouldn't paint springs, can make them bind.
springs don't "wear out".
Old Dec 26, 2005 | 03:26 PM
Narwhal's Avatar
Narwhal
Understand about the paint, but why would re-arched springs sag on one side and not the other? BTW, I'm just outside Winston-Salem.
-Scott
Old Dec 26, 2005 | 03:43 PM
WillyB's Avatar
WillyB
What did the guy who rearched your springs say? Have you asked him what gives?
Old Dec 26, 2005 | 04:16 PM
AXracer's Avatar
AXracer
I suspect your spring may have been replaced sometime with one that has too little temper, or the grinding got them hot enough to draw some of the temper out? Did they rearch both sides the same? Typically the left spring has more arch than the right when new (the reason there is a left and right to begin with) to allow for the additional settling on the left that will naturally occur, but the difference I'd expect is more in the 1/2-3/4" range. At this point I'd probably take the stacks apart and compare the leaves side to side to see where the sag is ocuring. If most of the leaves match, but one or two are obviously different, I'd replace those leaves on both sides.
We race up your way a few times a season.
Old Dec 28, 2005 | 06:43 AM
Narwhal's Avatar
Narwhal
I took the springs back the the shop and they said that they would rework them no charge. I explained that they had settled over a couple weeks so that the left side was about 1.5" lower and they said that happens sometimes but they would fix it. I pick up the springs in the next day or so. Then we'll see.
During grinding the rust off, they never got hot enough to burn my hand much less draw the temper.
-Scott
Old Dec 28, 2005 | 06:56 AM
WillyB's Avatar
WillyB
Thanks for the word - please post again when you get them back. I wonder what happened - did they fail to do something, or do something wrong?
At least they stand behind their work, and you are not out a bunch of shipping!
