Front brake hose mount pictures
Old Oct 25, 2011 | 10:10 AM
3golfjack's Avatar
3golfjack
Trying to figure out the best location to mount the front brake line hose coming from the frame rail to the caliber. This is on a 56 with a MII. Trying to decide to go thru, under or over the frame rail. Pictures would be great.
Old Oct 25, 2011 | 11:02 AM
CdnWillyG's Avatar
CdnWillyG
Jack this is what I did for mine, I just used a bulkhead fitting and came thru the rail. The hose is factory Mustang ll and fits around the spring perfectly when the wheel is moved in either direction. I since have changed the brake tubing you see to include a loop, just easier to install.
Old Oct 25, 2011 | 11:07 AM
old_dan's Avatar
old_dan
Subscribed....I'd like to see some details on what other have done. I was basically planning to weld a couple of tabs on to the frame. The engine is close to the top of the crossmember, and the steering is directly in front, so I was thinking that I'd install a couple of adel clamps on the back of the crossmember to fasten in the hard part of the line, then route that to the top of the frame. I'm thinking that, in a small way, over the frame will give the lines a little bit of protection from road debris.
Dan
Old Oct 25, 2011 | 11:13 AM
3golfjack's Avatar
3golfjack
Thanks for the picture. I see you are coming from the front with the hose running with the rail. I wasn't sure if the hose came from in front of the wheel or behind.
Old Oct 25, 2011 | 11:20 AM
CdnWillyG's Avatar
CdnWillyG
I came from the front because I'm boxed all the way from near the rad crossmember to almost to my cab mounts and this was where I had access to the brake tubing. I also found that if I came from the back it gave the brake hose a funny bend which I didn't like. Either way will work ...your preference.
Old Oct 25, 2011 | 12:44 PM
BACAGrizz's Avatar
BACAGrizz
Timely question. I just did mine Saturday after a few weeks of deliberation. MII with air ride and disc brakes.
Full range of motion (up, down and turning) without binding or rubbing.
Old Oct 25, 2011 | 09:09 PM
carnut122's Avatar
carnut122
That's pretty much how I did mine. The bulkhead through the frame seemed cool, but it seemed like one more fitting that might leak.
Old Oct 26, 2011 | 12:18 PM
jniolon's Avatar
jniolon
old and in the way
here's mine... when it was originally done wth the Volare... using same stuff on the MII
john
Old Oct 26, 2011 | 01:18 PM
old_dan's Avatar
old_dan
Nice....where did you get the bulkhead fittings to go through the boxed frame??
Dan
Old Oct 26, 2011 | 01:58 PM
jniolon's Avatar
jniolon
old and in the way
Dan
I don't remember where I bought mine but here is a source...
SSBC:: A0767
or do a google search on thru frame fittings
john
Schuyles
Aug 31, 2016 10:18 AM
ericconn
16
Dec 3, 2013 02:36 PM
kraylake
Oct 12, 2013 04:08 PM
Otis 54
Jun 25, 2013 09:21 PM
