Mounting front rubber brake hoses to frame?
Hi everyone. I'm looking for ideas on how to secure the front runner brake hose to the hard line inside the frame. The speedway disc brake kit came with the below, I assume to be attached to the frame as a mounting point, but I feel like there has to be a simple way that I'm missing. I want the hose to go to the existing hole.
Any ideas or pictures you can share?
Thanks!
Thanks!
Thanks!
Attachment 156257
Thanks!
Attachment 156257
If the new brake hose is keyed to fit that bracket then cut the 90 degree tab off the bracket, trace the shape of the keyed piece on the frame rail over the original hole, cut out the frame and weld the bracket piece flush into the frame rail. Should look factory that way. This assumes your lines are feeding through the side of the frame rail, my F1s had tabs like the speedway pieces that I modified for jag hoses.
Justboy
02-09-2017 03:49 PM
Otis 54
06-25-2013 09:21 PM
3golfjack
10-26-2011 01:58 PM
wosborn
05-25-2004 07:31 AM
