Barn Door Victory!
Old Oct 25, 2011 | 08:54 AM
SilverE350's Avatar
SilverE350
Barn Door Victory!
After lining up the doors and strikers so they would close properly and stay that way, I decided to insulate them.
I filled the side and rear doors with 3" "Roxsul Safe n Sound" and then taped Refletix to the inside of the door panels as well as the trim around the windows. What an improvement! Gone is the tinny echo when the doors close, replaced with a luxury car thud.
Old Oct 25, 2011 | 09:31 AM
JWA's Avatar
JWA
Very very cool Silver-----that extra paddng makes a big difference!
I filled all four of my rear area doors with the pink unfaced stuff then added plywood panels topped off with an ABS plastic pebble textured material usually found in commercial bathrooms. I'd found a set of factory cardboard panels for an early ('92 or so) van, made patterns and installed them with slotted body rivnuts and stainless steel truss head screws.
I added the Reflextic-like material to my driver/passenger doors too but I'd refitted my van with power windows and door locks so it was very easy to do. That too makes a difference and I swear the stereo sounds a bit better too!
Thanks for sharing!
Old Oct 25, 2011 | 01:16 PM
86scotty's Avatar
86scotty
cool, congrats! I need to as well but what you did is pretty time consuming!
Old Oct 25, 2011 | 01:39 PM
SilverE350's Avatar
SilverE350
Actually, insulating the doors took about 1 hour each. I had the materials in the back and did one at a time as time permited. I did one while waiting for my oldest daughter at dance and another while my two youngest were at music lessons.
Old Oct 26, 2011 | 05:09 AM
JWA's Avatar
JWA
Yeah this is easy enough to do, time permitting-----small bites, one at a time, no hurries and before you know its done. After completely just that first one the difference is immediately noticeable and we're suddenly motivated to do the rest.
Old Oct 26, 2011 | 05:36 PM
86scotty's Avatar
86scotty
Silver, where did you get the safe n' sound, mail order? Also, did you spray glue it in or just lay it in there? I was looking at it on Amazon but only saw about 1" looking sheets. Where did you get the 3"?
thx
Old Oct 26, 2011 | 06:23 PM
Henry10s's Avatar
Henry10s
Maybe USGBC should come up with LEED for vehicles. Only if the paperwork was easier!!!
Old Oct 26, 2011 | 09:28 PM
SilverE350's Avatar
SilverE350
Hey Scotty, the stuff I used is just sound insulation from Home Depot. It comes in 3" or 3.5" thicknesses. I used it in my house and it worked well, so that's why it is now in my van. The 3" fits perfectly in the door void (friction fit), is water resistant and has a higher fire rating than pink fiberglass. It comes in a similar bale as fiberglass. The Reflectix double double and double foil and is taped to the door panels because it was way easier than taping to the steel of the door and then making the panel hooks fit the door. Also, the way Reflectix works, is by using an air void to raise the R value, so I concluded that it needs to be away from the inside of the outer skin, the sound insulation providing the air void. I know many have glued it right to the outer skin with good results, but I'm not really into gluing anything and the tape seemed to work. The Reflectix will work on the outer skin, but will not gain R value like when used with an air space.
SAVOY05
2014+ Transit
Oct 29, 2015 09:13 AM
mysticalcracker
Jul 20, 2010 06:02 PM
rebocardo
Mar 15, 2009 09:35 AM
JohnMcHugh1
Aug 25, 2007 07:32 PM
BicycleMark
28
Jan 28, 2005 10:11 PM
