Van doors sprung
Same applies to the rear most passenger door. (side doors are OK, as is the driver side rear most door, as to 'not swinging free' but behaving as the doors should). The rear door came to me with a bungee cord, to clamp it to the rear wheel well, and keep it from slamming into me unexpectedly. Again, where to start is the question I have. All replies are valued.
While on doors, my front passenger door 'lock' is not connected to the top indicator. I should say, when I key the lock, I can hear it work, and cannot open that door lock with the key mechanism. I can access from inside, via the top 'indicator' (not sure what to call the screw on lock 'pulls'), to unlock and may use the door handle to open the door from inside. I suppose taking off the access panels I may find an obvious 'connection' point, buy a part or two, and that will be that. Just have not gotten to it yet. Anything to be aware of when removing, reinstalling the inside panels on the door? All manual locks (real manual these days), and manual windows.
Thanks
Instead of a "welding shop" I'd suggest a Body Shop. They'll be able to judge if the doors are sprung, can probably tweak them back in shape if not to far gone & fix the other things easily too. If its DIY only, hope you have a You-Pull type wrecking yard so you can acquire the small parts that are its sounds like you'll need. It might be worth a try to ask your local FORD body shop, could be easier than asking the parts counter for odd little parts.
From what I can tell, if the weld of the door skin has broke up at the front near the hinges, then the door integrity is bad and then the mechanism doesn't work. A body shop can reweld this. What I did (on my 91 caravan) was to put the door on the grass, bend the door frame with a pry bar to where it should be, and then bang the door skin back in place. I didn't need to have it tacked back together. However, your's may need to be rewelded.
On the rear door problem, you should see a rod coming out of the door at the jam that connects to a pin mounted on the van body. Those rods are removable so that the side and rear doors can be opened farther than 90°. Is that door's rod connected to the pin mounted on the van body? I've not ever had a problem with these so I don't know what it looks like inside the door.
PM me with your email and I can send you a few pics and some directions I have about the doors.
