I am absolutely enjoying my truck but the thought of not being able to trouble shoot it is a concern. My worst fear was realized today when the engine bucked and then ran with almost no power but now seems to be running fine. I hate going to the dealership.
The AE seems advanced and upgradable but I'd have to keep a laptop around, charged and the version of Windows current. My truck isn't getting any computer upgrades so why should I have to keep my diagnostic tool upgraded?
Don't know much about the Scan Tool so I don't know where to find out more about it and possibly purchase it.
I'll call Clay when/if I get out of jury duty this morning. I'm wondering if the Scan Guage will give pressure readings like the HPOP and the transmission.
Here is a link to the user manual for version 2.7 software, which you will need as it is not supplied with a scan gauge. OBS trucks use the Ford platform #2 parameter set.
so scan gauge hooks in ob port? man didnt no it did all that it dose, and can do mpg? hmmm may look more in to this
No MPG, our OBS rigs don't have the required sensors. However if you hooked it up to a Ford gas rig then it should work.
Here is a overview what does work on OBS trucks ...
Platform 2 parameters:
1. INTAKE AIR 2- Intake Air Temperature
2. RPM 2- engine Revolutions Per Minute
3. Manifold PSI 2 – Manifold Air Pressure (psia) for frequency based MAP
sensors
4. BOOST 2 – Boost Pressure in psig for frequency based MAP
5. MILES PER HOUR 2- Miles Per Hour
6. TRANS TEMP 2 – Trans temp derived from the trans temp sensor
voltage for 1997 and older trucks.
7. TRANS VOLTS – Transmission temperature sensor raw voltage.
8. RUN TIME MINS- engine run time since last engine start. Can be used
as a trip timer.
9. BATTERY VOLTAGE- Alternator/battery output voltage
10. PULSE WIDTH- injector pulse width in msec
11. ENGINE OIL TEMP
12. EX. BACK PRESS – Exhaust back pressure
13. ICP DC – Injector Control Pressure Duty Cycle
14. ICP – Injector Control Pressure
15. CURRENT GEAR – Current Transmission Gear
Whats the going price on that bad boy? It will work on the SD 7.3 also correct?
I dont know the actual price, but yes it works on SDs too.
I have it and I like it, I still dont know who to put all the amennities (spl?) on it, but till I know it has warning ligths too.
(I have to PM Jim [Hussler] to learn)
