C6 Third and Reverse.
Old Oct 23, 2011 | 01:04 PM
rwperkinsjr's Avatar
rwperkinsjr
Cool C6 Third and Reverse.
Hello, Noob here please be patient.
I recently bought a 1986 F-250 4x4 6.9L IH
The guy said the tranny leaked a little. I looked under it and found that the tranny cooling lines were leaking and the pan was leaking. I tightened the lines and replaced the filter and pan gasket.
While in there I noticed that the fluid was pretty dark and has a slight burnt smell to it.
I have checked vacuum and it seems well, shifts into reverse and drive just fine but slips in reverse and third and does not seem to shift down at lights until I give it some power.
I think I have found the answer but I want a second opinion from ya'll here.
Thanks in advance, if you have questions or need more input please ask and I will reply with any info you may need to help me solve this problem.
Old Oct 23, 2011 | 01:09 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...g-reverse.html Click on this link and have a read.
Old Oct 23, 2011 | 02:04 PM
rwperkinsjr
That's What I Was Afraid Of.
Of course... Thanks for prompt reply I really appreciate it. Time to get down and dirty and yank this thing out I guess. Good thing and no wonder I got it for 500 under book.
Old Oct 23, 2011 | 02:38 PM
Gary Lewis's Avatar
Gary Lewis
The burnt smell is a sure sign of slipping. But, depending on what you want the truck to do, sometimes a change of fluid, including that in the torque converter, works wonders - at least for a while. The friction-modifier chemicals wear out and new fluid usually makes it shift better.
Old Oct 23, 2011 | 03:36 PM
rwperkinsjr
I think I will take your advise and change ALL of the fluid first. I put 4 or 5 quarts in when I changed the screen/filter and it seemed to do a little better but then started failing again. I am thinking that the old contaminated the new (of course it would).
If this does not work I guess I will get my hands dirty and rebuild my first automatic transmission. I have done several engines but never a tranny. I have also looked on craigs and found a c6 from a 429 locally for $150.00. I may check on that and rebuild the one that I have in the truck for an extra if the 420 IH engine and 429 gas engines have the same bolt pattern.
I noticed a lot of sludge in the pan too. It didn't seem to be metal and no big parts where present. I assumed it was from the leak in the cooler line maybe sucking in dirt. Could the valve body be a culprit? Just grasping at straws... I think when I pull the pan again I will pull the valve body and make sure it is all clean too.
Last edited by rwperkinsjr; Oct 23, 2011 at 03:39 PM. Reason: Added sludge discovery.
Old Oct 23, 2011 | 04:43 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Most likely, that black "sludge" in the bottom of the pan, is just the clutch friction material.
As for the 429 trans, pretty sure it would be a waste of time. The diesel has a unique bellhousing pattern.
Fresh fluid *may* extend the life of the trans for a while, but it's about due for a rebuild. The C6 is rather stout, but even they cannot function correctly with the clutches stripped of the friction material.......
Old Oct 23, 2011 | 05:45 PM
Gary Lewis's Avatar
Gary Lewis
A change of fluid MAY work. My son-in-law bought a Jeep Cherokee that slipped similar to yours. He had the fluid changed and it has worked well for over a year. But, he doesn't tow with it and it weighs lots less than your truck.
Having said all that, IF it works you are just buying time. RW is right that the clutch/band material was the sludge, and at some point they will have to be replaced. A lot depends on how you are going to use it and for how long. But, changing the fluid doesn't cost much and will clean it up internally so rebuilding takes less cleanup.
Aeromac121
Aerostar
Apr 12, 2006 03:39 PM
msfprobass
Oct 15, 2004 10:20 AM
msfprobass
Oct 14, 2004 06:02 AM
grasmussen
Mar 11, 2003 08:34 PM
Ltds03
1978 - 1996 Big Bronco
May 17, 2000 07:13 AM
