Aerostar Ford Aerostar
Shifting into reverse is not smooth.
Old Apr 11, 2006 | 11:14 PM
Aeromac121's Avatar
Aeromac121
My newly acquired 93 aero sport, 130,000 miles, feels like it's trying to self destruct when I put it into reverse. It feels like a big impact wrench, and sometimes it's kinda loud as all the slop gets used up and metal hits metal(or something) I don't know much about how transmissions work/shift so I don't have a clue how to address this.
Anybody have any ideas?
oh yeah, if it matters I recently dropped the transmission pan to install a temperature sending unit and replaced the filter and whatever fluid fell out of the pan. I'm aware that most of the fluid was still stuck in the torque converter, I just haven’t "gentle flushed" it yet. But this hard shifting was happening before I dropped the pan, so it didn’t get any better or worse when I messed with it.
Old Apr 12, 2006 | 02:32 AM
96_4wdr's Avatar
96_4wdr
http://autorepair.about.com/library/ts/at/bl-at-10.htm
Old Apr 12, 2006 | 08:24 AM
vwhed1979's Avatar
vwhed1979
reverse
Mine is a bit rough too. I did the filter, fluid, and flush, and didn't make much difference in reverse. The forward gears are much smoother though.
Old Apr 12, 2006 | 01:00 PM
Aeromac121's Avatar
Aeromac121
96_4wdr, which of those potential problems, in the link you posted, can be addressed without dropping the tranny?
Old Apr 12, 2006 | 02:49 PM
96_4wdr's Avatar
96_4wdr
#2. Main control assembly gaskets damaged or bolt out of torque
not common especially when only one gear is affected....usually blown gasket or loose valve body bolts cause multiple symtoms
fairly easy to retorque valve body bolts...drop tranny pan...start from middle and work out to edge
96 pounds inch w torque wrench, use a 3/8" break or digital style torque wrench, this is pounds inch which is 6 lbs ft
be careful removing bolts, 5 different lengths used in valve body, will cause damage if put in wrong holes
while you are under the rig, replace vacuum modulator, they fail often from exhaust heat breakdown and cause numerous problems, can damage engine and tranny, cheap insurance
if you have the 4L, remember to replace the modulator heat shield, many are left off, makes tranny shops lots of money from failed modulators, cooked Mercon and failed trannys
Old Apr 12, 2006 | 03:39 PM
Aeromac121's Avatar
Aeromac121
It's a 3.0. I may give that a shot. Also, I was looking around on the net and saw a thread on a different forum where the guy was documenting his A4LD rebuild. Towards the beginning of the teardown he says:
"One problem area that can be easily fixed with the transmission in the car is the low/reverse servo leakage problem - the delayed engagement in drive or reverse and the "jerk" on engagment
Does this sound correct?
Last night after reading about other tranny problems, I pulled the vacuum line on the modulator to check for fluid and it was dry. As suggested, I might replace it anyways just to see what happens.
I guess I should probably buy a smaller torque wrench, I've got a cheap one but it's the bending kind and it's at least a couple feet long.
Thanks for the help. I’ll keep you posted. Unfortunately I won’t be able to do any work on the van for about a week, give or take a few days.
brandon.
2004 - 2008 F150
Dec 7, 2012 05:35 AM
customcreationsllc
May 9, 2011 01:24 PM
JBronco
1978 - 1996 Big Bronco
Feb 8, 2005 08:25 PM
BillyBobSowbreath
1983 - 2012 Ranger & B-Series
May 11, 2004 08:34 PM
DailyDriver
Jun 24, 2003 10:51 PM
