What is a safe PYRO reading??
Old Oct 19, 2011 | 02:32 PM
Rollin.IH.Coal's Avatar
Rollin.IH.Coal
hey its me again, 86 6.9...
whats a safe egt value, shell be running empty 99.9% of the time. i turned up the pump.. maybe 3 flats maybe a tad more. wont hessitate to turn down. but she gets up to about 900ish. not too much more.
Old Oct 19, 2011 | 02:40 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I do believe it depends on pyro location.
But 0-1000 is the safe area. If your pulling heavy or whatever, you can go up to 1200 but try not to keep it at that for to long.
Old Oct 19, 2011 | 02:49 PM
Rollin.IH.Coal
the sensor is at the Y pipe
Old Oct 19, 2011 | 02:50 PM
IDIDieselJohn
Is it right behind Cylinder #8?
Old Oct 19, 2011 | 02:55 PM
Rollin.IH.Coal
where the two exuast manifold pipes come and connect into one. on the right side of the truck.under the firewall.about 2-3ft away from the engine
Old Oct 19, 2011 | 02:58 PM
IDIDieselJohn
Oh that's a little far.... and if your seing 900 there... ouch.
The limit I told you is the limit if the pyro was located just a couple inchs after cylinder #8, on the manifold.
Old Oct 19, 2011 | 03:13 PM
Rollin.IH.Coal
ooooh ****.. okey so i should throw her in a few from cyl 8? is that the hottest? ill just wield up the hole?
Old Oct 19, 2011 | 03:19 PM
LSO1123's Avatar
LSO1123
My probe is right where John is talking about and my pump is also turned up at least 3 flats. I can hit 1000 pretty easy if I get on it good. I was pulling a trailer loaded with 4 wheelers and tree stands up a long fairly steep hill the other day and hit 1300 for a minute or less when I wasn't paying attention. I switched the Optishift to manual and dropped it down to 3rd gear and the EGT came down quickly.
Old Oct 19, 2011 | 03:31 PM
IDIDieselJohn
Yeah..... if you were hitting 900 3ft. away from the engine, umm ouch. That's pretty severe.
Old Oct 19, 2011 | 03:40 PM
Rollin.IH.Coal
i planned on turning her down, i will relocate probe and turn down a flat. thank youu!!
Old Oct 20, 2011 | 01:56 PM
GHeTTo JOe's Avatar
GHeTTo JOe
just curious if anyone has had numbers from pre turbo and post turbo is the difference about 300 less?
Old Oct 25, 2011 | 03:32 PM
WesternStar's Avatar
WesternStar
I can tell u this. My truck came with an ATS 088 turbo and the pyro was located post turbo but just barely. The system either came with the bung there (it's almost like it's in the turbo housing) or someone put it there but it looks factory. Anyway my sender died and I couldn't get it out to save my life so I tapped a new sender hole into the pass side manifold, right in the middle of the 4 cylinders (had the best access there). Drove some familiar hills and the temp was the same in the manifold as it was in the previous location. I used to worry that I was losing a couple hundred degrees where it used to be... apparently not.
Old Oct 27, 2011 | 10:22 AM
farmert's Avatar
farmert
There was a thread over in the OBS stroke forum where a member got a different truck that had the pyro sensor located in the down pipe after the turbo. He wanted it pre turbo so added a new one, and ran them both for a test. Depending on how he drove he found 300 degrees difference between the two very easily. IIRR he even found 500 degrees difference when pulling a heavy load on a decent hill.
Old Oct 27, 2011 | 11:14 AM
Rollin.IH.Coal
so i put it in the manifold behind #8 or on the pipe the manifold connects to?
Old Oct 27, 2011 | 11:45 AM
farmert's Avatar
farmert
In the manifold at #8 is what is generally recomended.
mudrat025
16
Sep 19, 2013 10:17 PM
John311t
21
Jan 13, 2007 06:47 PM
PSD6litre40
Jul 29, 2004 06:02 PM
mediumfry
Feb 27, 2004 06:11 PM
HOpowerstroke
Feb 1, 2004 01:19 PM
