map sensor???
Old Sep 14, 2013 | 05:39 PM
mudrat025's Avatar
mudrat025
map sensor???
hello, i have a 1997 7.3 and pull a 10k toyhauler with and am not impressed on towing uphill at all!!it has a 5 speed with 4:10 gears, tymar intake, 6 position chip,3 inch drop pipe with the cat deleted,new glowplugs,new fuel pump bowl lines and filter. i am impressed with the power not under load but geez when towing the trailer this thing is a pig. my buddy last weekend made a joke out of this thing with his duramax blazing by me on hills??i have heard the map sensor can be the culprite. so from what i have searched just unplugging it and if there is a difference it is bad is what i am getting however will it be noticable without a load?i bought this thing for towing specific and am highly disappointed so any help will be much appreciated...dont make me trade her in on a duramax.
Old Sep 14, 2013 | 05:40 PM
mudrat025's Avatar
mudrat025
also i have found that ford did put in the wrong sensor on some of these trucks. how do i know what is right?
Old Sep 14, 2013 | 06:37 PM
427 fordman's Avatar
427 fordman
https://www.ford-trucks.com/forums/1...+clarification
Do you have any gauges? What chip do you have? Do you have any boost/exhaust leaks?
Old Sep 14, 2013 | 09:35 PM
mudrat025's Avatar
mudrat025
unfortunately no gauges yet as everything has gone to keep pig running.i have ts performance chip,when local diesel shop put on down pipe they looked for leaks and said everythings tight...
Old Sep 14, 2013 | 11:00 PM
oldbird1965's Avatar
oldbird1965
Your not going to get any arguments from anybody here that these trucks are pigs stock. Keep reading and you can turn yours into a good hauler. Darin and I both pull 16K trailers in good shape.
Old Sep 15, 2013 | 09:05 AM
mudrat025's Avatar
mudrat025
Thanks fordman at least I know I got the right sensor.what do you guys think about a scangauge?they seem comparable in price to a gaugw cluster...
Old Sep 15, 2013 | 09:12 AM
oldbird1965
I like my scangauge but it doesn't read EGT's.
Old Sep 15, 2013 | 09:36 AM
madpogue's Avatar
madpogue
Can't you get an EGT sender and tie it to the Scangauge?
Old Sep 15, 2013 | 09:42 AM
mudrat025's Avatar
mudrat025
Oldbird what scangauge would you recommend?
Old Sep 15, 2013 | 09:49 AM
fordpride's Avatar
fordpride
If your tuning is from TS performance then that's your problem.
Old Sep 15, 2013 | 09:59 AM
mudrat025's Avatar
mudrat025
Chip seems to be working properly???
Old Sep 15, 2013 | 10:21 AM
oldbird1965
Aeroforce Technology Inc | Products - Interceptor
Old Sep 15, 2013 | 08:22 PM
fordpride's Avatar
fordpride
I had there tunes. They suck. I bet it you were to put you truck on a AE to see live data you'll see a bunch if thing that not right. Like WOT being around 65% of the go pedal. Your HPO being limited. IPR being limited to around 45% dc just for starters. Them moving WOT is a trick to give you that WOW factor making you think you have a lot more power. And if you had a EGT gauge you'd see that temp are really high.
Old Sep 15, 2013 | 10:15 PM
lindstromjd's Avatar
lindstromjd
Might want to check for boost leaks while you're at it.
Old Sep 16, 2013 | 06:49 AM
mudrat025's Avatar
mudrat025
i was going to have the tunes reburned soon...i will check for leaks again and get some gauges.keep you posted.thanks
