If the trans is out of the truck (easy access) and you have the time & money, I would go with the Trans-go "Tugger" kit. It has some Tq converter mods and increases holding pressure in First & Reverse...that would be just the ticket if you plan on doing some serious towing.
what do you think "the punisher" does to the valve body?
hint; he's not using factory parts.
I know I don't care what parts he uses. He is one of the best trans builders out there and there isnt any beating a punisher valvebody for an E4OD. He will also customize them to your application. Some PSD guys run them as well.
You can go on NLOC and ask about them if you don't believe me when I say there is nothing better for an E4OD.
