06 6.0 no start
Old Oct 18, 2011 | 08:45 PM
bigbadwolfe's Avatar
bigbadwolfe
06 6.0 no start
well thats what i have and as you know it will not start i drove it about 100 miles on sunday night got home shut it off and then went to the store later that night shut it of and went in the store came back out and no start tried a few things no go pulled the fuel filter and the bowl was filling up so the pump is good but no smoke when cranking got it towed home the next morning come out to try it and it started ran like dog doo-doo took it around the block ran rough pulled back into the driveway and it died again from what i have been reading i am thinking it is the ficm but what do you think
Old Oct 18, 2011 | 09:05 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
It could be the FICM, but it sounds like the STC fitting may be loose.
They symptoms of a failing STC fitting are close to what you described: when warm truck will crank, but not start. When cold, the truck may restart and run normally or start normally and idle rough.
You may also check the ICP sensor located on the passenger side valve cover. Unplug the sensor, if it starts runs, and drives somewhat normally, that may be your problem.
Old Oct 19, 2011 | 07:28 AM
npccpartsman's Avatar
npccpartsman
Yup. Definitely need to check the FICM voltage per the test procedure in the tech folder at the beginning of the 6.0 forum. Also need to verify ICP and IPR values while cranking the truck. I suspect an STC fitting blowout also.
Old Oct 20, 2011 | 06:43 AM
bigbadwolfe
what and where are the stc fitting
Old Oct 20, 2011 | 10:05 AM
murraydav's Avatar
murraydav
Here's a great 2 part video on the STC
6.0 Liter Ford Powerstroke - High Pressure Oil Pump & STC Fitting Part 2 - YouTube
Find part one first. I bought Ford original equipment part on E-bay for 29 bucks
Old Oct 20, 2011 | 06:07 PM
bigbadwolfe
how common is this
Old Oct 20, 2011 | 06:18 PM
NewToDiesels's Avatar
NewToDiesels
Originally Posted by bigbadwolfe
how common is this
Pretty common for the symptoms you describe.
It would be great if you could use a scanner to help diagnose the issue. Did you get it scanned for codes? A lot of guys here use a ScanGauge II to monitor the motor and it also can get a lot of the codes the computer throws. The check engine light does not have to be on for a code to be stored.
Old Oct 21, 2011 | 06:30 PM
bigbadwolfe
if the stc was no good would you lose oil too
Old Oct 21, 2011 | 06:36 PM
NewToDiesels
Nope. Leaking oil stays contained in the motor.
Old Oct 21, 2011 | 07:03 PM
cheezit's Avatar
cheezit
just how much oil are you loosing? is it leaking on the ground or do you belive its being burnt.
so far as your no start goes. not much I can offer with knowing what ICP, IPR and ficm readings are.
johnbeers08204
Apr 18, 2018 11:24 PM
J.TKPowerstroke
Jul 13, 2012 09:29 PM
QCIGUY
Jun 17, 2010 10:38 PM
DarkSide60Effie
Jan 10, 2009 07:17 AM
mingiz
General Diesel Discussion
16
Aug 31, 2008 05:34 PM
