shift actuator
Old Oct 18, 2011 | 02:10 PM
wizzy214's Avatar
wizzy214
shift actuator
96 e250 I6, auto
how hard is it to replace the shift actuator?
when you start out driving you have to put it in 1st then 2nd then (D).
is it the shift actuator thats bad or is it the tranny going south?
thanks
Old Oct 18, 2011 | 06:51 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What happens if you just put it in D?
Old Oct 18, 2011 | 07:25 PM
wizzy214's Avatar
wizzy214
you have to pedal it and then it goes.
Old Oct 18, 2011 | 08:35 PM
IDIDieselJohn's Avatar
IDIDieselJohn
What tranny does it have? Is it the 3 speed?
Or is there a OD cancel switch on the column shifter?
Old Oct 18, 2011 | 09:12 PM
Mark Kovalsky
I suspect a bad seal in the forward clutch. Same answer for either the three speed or the four speed.
Old Oct 18, 2011 | 10:01 PM
wizzy214's Avatar
wizzy214
stadard 3 speed with overdrive.
there is an overdrive switch on the shifter
Old Oct 18, 2011 | 10:03 PM
wizzy214's Avatar
wizzy214
how hard is that to replace? or do you have to drop the tranny?
Old Oct 19, 2011 | 04:59 AM
Mark Kovalsky
No such thing. It's a four speed overdrive.
It's a rebuild. The trans comes out of the truck and gets torn down. While it is apart it makes sense to rebuild it.
Old Oct 19, 2011 | 12:01 PM
wizzy214's Avatar
wizzy214
whoa, wanst thinking that was gunna happen, whats a rebuild cost vs getting a used one on craigslist?
Old Oct 19, 2011 | 08:42 PM
Mark Kovalsky
A rebuild is more than $2000 and less than $5000 depending on how strong you have it built. A Craigslist trans is less than that. Remember, you get what you pay for.
66_in_ky
May 6, 2010 09:25 PM
alhanson
Sep 10, 2007 08:38 PM
robert collison
Mar 13, 2006 02:57 PM
quads
Nov 10, 2000 03:23 PM
