shift actuator
Oct 18, 2011 | 02:10 PM
shift actuator
96 e250 I6, auto
how hard is it to replace the shift actuator?
when you start out driving you have to put it in 1st then 2nd then (D).
is it the shift actuator thats bad or is it the tranny going south?
thanks
Oct 18, 2011 | 06:51 PM
What happens if you just put it in D?
Oct 18, 2011 | 07:25 PM
you have to pedal it and then it goes.
Oct 18, 2011 | 08:35 PM
What tranny does it have? Is it the 3 speed?
Or is there a OD cancel switch on the column shifter?
Oct 18, 2011 | 09:12 PM
I suspect a bad seal in the forward clutch. Same answer for either the three speed or the four speed.
Oct 18, 2011 | 10:01 PM
Quote:
Originally Posted by
IDIDieselJohn
stadard 3 speed with overdrive.
there is an overdrive switch on the shifter
Reason: reason for Editing:
Oct 18, 2011 | 10:03 PM
Mark Kovalsky
how hard is that to replace? or do you have to drop the tranny?
Oct 19, 2011 | 04:59 AM
wizzy214
No such thing. It's a four speed overdrive.
wizzy214
It's a rebuild. The trans comes out of the truck and gets torn down. While it is apart it makes sense to rebuild it.
Oct 19, 2011 | 12:01 PM
whoa, wanst thinking that was gunna happen, whats a rebuild cost vs getting a used one on craigslist?
Oct 19, 2011 | 08:42 PM
A rebuild is more than $2000 and less than $5000 depending on how strong you have it built. A Craigslist trans is less than that. Remember, you get what you pay for.
66_in_ky
May 6, 2010 09:25 PM
alhanson
Sep 10, 2007 08:38 PM
robert collison
Mar 13, 2006 02:57 PM
quads
Nov 10, 2000 03:23 PM
150 ,
2007 ,
accuator ,
actuator ,
automatic ,
bad ,
collum ,
f150 ,
ford ,
replace ,
shift
