351 windsor problems
ok i have a 1985 f250 light duty with a 351w auto trans and i having some simple problems, when i shift out of park and shift in to drive i wants to cuts out or idles real low and u have tromp/hold on the gas for it stay running its sucks, ive messed with the distrbutre, carb but still the same resultes weird idleing so plz help me!!!
When was the last tune-up? Plugs, ignition wires, cap and rotor?
When you said "messed with the dist, carb", what did you do? What is the current timing set at? When was the carb last rebuilt? Have you checked mixture and bowl levels?
What RPM is the truck at when idling in Park?
Gotta know these things in order to help you.
Don't forget the fuel filter. As it starts to move, and requires more fuel, if the filter is clogged, it will starve for fuel and die when you try to move, or at best, be a total dog. Don't know if it applies in your case, but it's an easy thing to check, and equally easy to overlook. Good luck.
Tell us EXACTLY what you've done so far, and to what specifications, and we'll be better able to help. You need to be precise...this is the internet and we can't read minds, or look over your shoulder. (that is just a truism, NOT to criticize) The more you help us, the better we can help you.
Ripperg9
16
10-11-2011 02:38 PM
84-F150
12-27-2006 06:42 PM
colorado hick
02-02-2006 05:25 PM
