Help!!! big power loss under load
Old Feb 1, 2006 | 05:15 PM
colorado hick's Avatar
colorado hick
Hello,
I have a '78 F250 4X4 with the C6. My engine caught on fire a couple months ago, so I got a new carb from national carberator, and new distributer/cap/rotor/wires from NAPA. After I got it put back together, I developed a nasty rod knock and dropped in a 400 CID rebuilt block. So now almost everything under the hood is new, but my truck does not run that well. When ever I step on the gas when I am on a hill, it sputters and has even stalled out. It tends to want to give small back fires when I step on the gas. The funny thing is that when it is in park it runs great. Any ideas?
I was thinking maybe my carb was under-jetted, I had a 351M engine before, the jets in it are 57s, im at 5000 ft elevation,
The distributer does advance the timing when I suck on the air line,
I have gone through 2 cans of choke cleaner looking for air leaks and found none,
Brand new spark plugs,
I was thinking it may be a fuel line or filter, but I dont understand why that would give me problems at low RPM (but I am not sure. Is there any other filters besides the one on the carb)?
Thanks in advance for any help!!!
Jon
Old Feb 1, 2006 | 07:15 PM
WrenchHead84's Avatar
WrenchHead84
From what's been described, it really sounds like the timing is off. I would verify timing. Also, what about the possibility of having a couple plug wires cross. If you 1 on each bank crossed, it can still idle smooth and run ok while not under load, but it would be running on 6 instead of 8-I have seen that before.
Check the accel. pump on the carb, proper fuel volume, fuel filter, and I would definately tune the carb for the bigger engine. But I'd get ya a nice 4-bbl carb, unless you've already got one.
Let me know how it turns out
Old Feb 1, 2006 | 07:48 PM
colorado hick
Thanks for the leads. Is there any other fuel filters besides the one on my carb? How to I verify fuel volume? what is the firing order for a 400?
thanks again!
Jon
Old Feb 1, 2006 | 08:11 PM
76 F-150 390FE's Avatar
76 F-150 390FE
dont know about the fuel filters but i got the fireing order
1-3-7-2-6-5-4-8
dizzy spins CCW
#1 is the one twords the front of the rear clip on the cap.
Old Feb 1, 2006 | 09:22 PM
Mil1ion's Avatar
Mil1ion
Is this engine a hi-miler with a worn out timing chain and gears ?
Is the distributor worn out ?
There is only the one filter in the line at the carb.
The pickup tube in the fuel tank however has a special material that can clog from debris in the tank.
Old Feb 1, 2006 | 09:43 PM
colorado hick
The engine is a rebuild, less then 200 miles on the timing chain and gears. The distributer is also a recent reman. I have factory dual tanks, and I get the same problem with both tanks, so I doubt it is the material in the tank.
If I was having fuel delivery issues, wouldn't that show up at high RPMs more then low RPMs?
Old Feb 1, 2006 | 09:51 PM
Mil1ion's Avatar
Mil1ion
Back-firing means Timing Issues.
Old Feb 1, 2006 | 11:10 PM
Bdox's Avatar
Bdox
If it's backfiring through the carb, it can also indicate a lean condition. Backfire through the exhaust can be a rich condition. Either one can be agrevated by incorrect timing or incorrect firing order.
Old Feb 2, 2006 | 05:25 PM
WrenchHead84
There should a filter inline to the carb. There should also be a strainer/screen on the sender unit in the tank.
