351 windsor problems
Old Oct 13, 2011 | 11:51 PM
Warrior449's Avatar
Warrior449
ok i have a 1985 f250 light duty with a 351w auto trans and i having some simple problems, when i shift out of park and shift in to drive i wants to cuts out or idles real low and u have tromp/hold on the gas for it stay running its sucks, ive messed with the distrbutre, carb but still the same resultes weird idleing so plz help me!!!
Old Oct 14, 2011 | 05:18 AM
AstroFab's Avatar
AstroFab
Raise the idle speed?
Old Oct 14, 2011 | 07:06 AM
Anafiel's Avatar
Anafiel
When was the last tune-up? Plugs, ignition wires, cap and rotor?
When you said "messed with the dist, carb", what did you do? What is the current timing set at? When was the carb last rebuilt? Have you checked mixture and bowl levels?
What RPM is the truck at when idling in Park?
Gotta know these things in order to help you.
Old Oct 14, 2011 | 08:16 AM
86fordtruck's Avatar
86fordtruck
Don't forget the fuel filter. As it starts to move, and requires more fuel, if the filter is clogged, it will starve for fuel and die when you try to move, or at best, be a total dog. Don't know if it applies in your case, but it's an easy thing to check, and equally easy to overlook. Good luck.
Old Oct 14, 2011 | 11:12 AM
Warrior449's Avatar
Warrior449
ok i will check these things and get back to u guys with rpm,oil presure, i mite put a vid up to show what it dose, ok thanks everyone
Old Oct 14, 2011 | 02:44 PM
roadrash63's Avatar
roadrash63
hey
check your vacum lines
maybe pcv valve hose at the back of the carb.
good luck
Old Oct 14, 2011 | 04:01 PM
Anafiel's Avatar
Anafiel
Originally Posted by roadrash63
hey
good luck
Yup, good call. Vacuum lines are always an issue on our trucks if they haven't been replaced in the last 20 years or so. I'd go ahead and do that "just because", and change the PCV valve with a Motorcraft valve while your at it.
Tell us EXACTLY what you've done so far, and to what specifications, and we'll be better able to help. You need to be precise...this is the internet and we can't read minds, or look over your shoulder. (that is just a truism, NOT to criticize) The more you help us, the better we can help you.
Old Oct 18, 2011 | 11:40 PM
Warrior449's Avatar
Warrior449
i have check these things it has a edelbrok carb i got it a little better i messed with the fuel mixter it will shift fine wen warmed up, it loads up but a little twecking it should be right, and it has vac lines and we pluged them up wen we got the truck cuz it was running so crapy so?
Ripperg9
16
Oct 11, 2011 02:38 PM
84-F150
Dec 27, 2006 06:42 PM
colorado hick
Feb 2, 2006 05:25 PM
tegger
Jun 3, 2005 03:04 PM
85bronco
1978 - 1996 Big Bronco
May 23, 2001 11:45 PM
