5 Speed launch tips?
Old Oct 18, 2011 | 11:54 AM
MagKarl's Avatar
MagKarl
1st in a ZF5 is not a granny. You need a ZF6 for that. Starting in 2nd justs puts more wear and tear on your clutch. I think it's fair to say if you kill the engine just getting the truck rolling from a stop sign, you probably ought to be using a lower gear.
Old Oct 18, 2011 | 11:59 AM
Talyn's Avatar
Talyn
Coulda fooled me on that one.
Old Oct 18, 2011 | 12:11 PM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
not to hijack or anything, but how can you tell what zf you have?
Old Oct 18, 2011 | 12:14 PM
Talyn's Avatar
Talyn
5 speed or 6 speed.
Zf5 or ZF6. =)
The Low gear on the zf6 is almost identical to first on the zf5.
Most people I know with a zf6 still start in 2nd though, cause 1'st is pretty short still.
Old Oct 18, 2011 | 12:20 PM
f350rebel7788
Originally Posted by Talyn
5 speed or 6 speed.
Zf5 or ZF6. =)
wow... i thought it would be complicated or something... lol now i feel dumb... lol
Old Oct 18, 2011 | 12:22 PM
Talyn's Avatar
Talyn
Well, there are 2 versions of the zf5. ... hehe.
96-97 had an upgraded version of the zf5. They are both great transmissions, but the extra's on the 47 are a little nicer.
Old Oct 18, 2011 | 12:23 PM
f350rebel7788
ahhh, gotcha. so since i've got a 94, mine only has one possible zf5...
Old Oct 18, 2011 | 12:24 PM
Talyn's Avatar
Talyn
Yeah, 42, just like me. =)
You can see the "techy" name for it in my signature there.
Old Oct 18, 2011 | 12:27 PM
f350rebel7788
oooh, fancy lol
Old Oct 18, 2011 | 12:28 PM
Talyn's Avatar
Talyn
oooh, fancy lol
I'm silly like that. =)
Old Oct 18, 2011 | 02:48 PM
rideracelivemx7's Avatar
rideracelivemx7
well ill toss in my pennys worth.
i found out that just becuase i have a bid expensive clutch DOES NOT mean you can be doing 4 wheel launch's and burn outs and what not. i dropped a nice dime on a valair clutch and almost exactly a year later i was replacing it with another one. and the one i have id say is a litttttle stronger than a stocker.
word of advance, slip the least amount possible and stay away from high revs when slipping/launching the truck.
if you want the fun stuff save up for a triple disk! lol
Old Oct 18, 2011 | 06:20 PM
ReFlectiveMan's Avatar
ReFlectiveMan
Bah, Delete ,my post
Old Oct 18, 2011 | 10:33 PM
  #28
Major Marvin's Avatar
Major Marvin
Originally Posted by Neal 97 250
I have 4.10 gears and I always use first gear. Yes it is only for a second then shift then two seconds and shift into third and away we go.
My truck does not like starting in second gear at all. I even do better times at the strip when I use first. Go figure.
When starting at a red light I start in first and I am shifting into third by the time I cross the other side of the intersection.
Starting in second will wear the clutch prematurely.
Same way for me, I limit slippage as much as possible. The topic is takeoff but I just tend to baby my rig. I will punch it in 3rd once in a while to blow the cobwebs out but that's about it. Any sort or premature wear is out of the budget.
Old Oct 19, 2011 | 08:05 AM
  #29
Talyn's Avatar
Talyn
if the clutch is locked, and doesn't slip due to wear, you dont have to worry.
But yeah, taking off can be a beotch.
But there are lots of ways to "practice" with a clutch that wont pre-maturely wear it out.
savage250
Jan 24, 2012 05:15 PM
chapinmesa
Apr 9, 2010 11:45 PM
66flareside
Dec 17, 2008 07:11 AM
Miller
Aug 5, 2008 08:52 PM
Bob_Smith
1997 - 2003 F150
Mar 10, 2006 12:24 AM
