Brake problem
Old Oct 18, 2011 | 11:03 PM
SUMPER's Avatar
SUMPER
Question Brake problem
I have a 97 F-250 7.3 When I start it up in the mornings the brake light comes on. When I head down the street the brakes are not good, but as soon as I run up the rpm's the light goes off and the brakes are fine. Is it my power booster? It also does it when driving and stopping at lights when I idle down but goes off when run at higher rpm's
Old Oct 18, 2011 | 11:27 PM
madpogue's Avatar
madpogue
"Not good" ==> hard pedal? If so, this is sounding like a vacuum pump issue. Vac pump is weak, below "margin" at idle, but adequate when revved up. Either that or the belt is loose.
Any other belt-accessory-related problems (charging, cooling, power steering, etc.)?
Old Oct 18, 2011 | 11:35 PM
SUMPER's Avatar
SUMPER
No other problems so don't think it is the belt.
Old Oct 19, 2011 | 08:36 AM
tjc transport's Avatar
tjc transport
i ain't rite
sounds like your vacuum pump is dying.
Old Oct 19, 2011 | 11:11 AM
BuckHammer's Avatar
BuckHammer
I concur with Tom's assessment.
Old Oct 19, 2011 | 12:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
One more for vaccum pump issue
mozzles
Aug 20, 2014 09:09 AM
OldWoodsDiesel
Jan 7, 2013 08:00 AM
turbill
Jan 31, 2011 03:57 PM
weldboy
May 20, 2004 07:56 PM
obidan
Jul 21, 2003 10:43 PM
