????? About Scan guage ll
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Boost
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: BST
With a little tweaking you can adjust this to read boost as you said.
To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
14.0 -- FF74 (I USE THE "FF71" FOR MY AREA, IT WORKS GREAT)
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
VREF (My notes indicate that this is the Calibration Voltage Input, comment by James )
TXD: 07E0221155
RXF: 046205110655
RXD: 3010
MTH: 000133330000
NAM: CVI
EBP
Exhaust Back Pressure
07E0221445
046285140645
3010
001D00500000
EBP
Engine Oil Temp.
07E0221310
046245130610
3010
00090005F05F
EOT
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 0064010000000
NAM: FLP
FICM Main Power (Volts) (Should be 47-48) (this does work! )
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP
FICM Vehicle Power (Volts) (Should be 12 Volts)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
Fan Speed Sensor (RPM) (THIS ONE IS WORKING AS "RPMS" NOW)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
Gear
TXD: 07E12211B3
RXF: 0462051106B3
RXD: 3008
MTH: 000100010000
NAM: GER
IA2 Sensor (STOCK GAUGE IS "f*AT" AND READS 10-13 DEGREES LOWER THAN THIS IA2 GAUGE)
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Inj. Control Press.
07E0221446
046205140646
3010
003900640000
ICP
ICP Voltage (Volts) (THIS ONE ISN'T WORKING ON MINE YET, NOT SURE WHY!)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
IPR Duty Cycle
07E0221434
046285140634
3008
0DCA03E8000A
IPR %
Mass Fuel Desired (in milligrams perstroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
Sync (1 = in sync, 0 = not in sync) (NOT SURE WHAT THIS ONE DOES, BUT CHEEZIT SUGGESTED IT.)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3701
MTH: 000100010000
NAM: SYC
Trans. Fluid Temp.
07E1221674
046205160674
3010
000100080000
TFT
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
