Scan Gauge II settings??
Old Oct 1, 2011 | 05:11 PM
TomCat-F350's Avatar
TomCat-F350
Installed my new 4" MBRP turbo back on my 2005 6.0 and also bought new Scan Gauge II and was wondering what gauges to mainly monitor. I was thinking about the engine oil temp, coolant temp, tranny temp, and boost. Any suggestions?? I would rather not keep changing all the time and look at the best and most important ones monitor. There are so many I am not sure what is best. I have no other sensors like fuel pressure or EGT. Thank you for any sugesstions.
Old Oct 1, 2011 | 05:22 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
boost you get from the PCM isn't a true value. it's a calculated value. I'd get a real gauge for that
I suggest you do ECT, EOT, FICM Volts, Batt Volts as main gauges. keep Trans Temp as a quick hotswap for when towing
Old Oct 1, 2011 | 06:06 PM
TomCat-F350
How much over 12V should I consider normal? At what point is it time to worry. I was getting 12.4 with the engine running. I was thinking it should be higher with the Alt. feeding the batteries.
Old Oct 1, 2011 | 06:37 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here are the Xgauges I now have entered in my Scangauge II. The ScII reads x gauges from #24 to #0 So I entered them alphabetically by name for easy access. I normally run:
FMP, ECT,EOT, VOLTS. While towing I will switch to add Fan speed and TFT.
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Boost
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: BST
With a little tweaking you can adjust this to read boost as you said.
To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
14.0 -- FF74 (I USE THE "FF71" FOR MY AREA, IT WORKS GREAT)
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
VREF= Voltage reference
TXD: 07E0221155
RXF: 046205110655
RXD: 3010
MTH: 000133330000
NAM: CVI
EBP
Exhaust Back Pressure
07E0221445
046285140645
3010
001D00500000
EBP
Engine Oil Temp.
07E0221310
046245130610
3010
00090005F05F
EOT
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 0064010000000
NAM: FLP
FICM Main Power (Volts) (Should be 47-48) (this does work! )
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP
FICM Vehicle Power (Volts) (Should be 12 Volts)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
Fan Speed Sensor (RPM) (THIS ONE IS WORKING AS "RPMS" NOW)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
Gear
TXD: 07E12211B3
RXF: 0462051106B3
RXD: 3008
MTH: 000100010000
NAM: GER
IA2 Sensor
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Inj. Control Press.
07E0221446
046205140646
3010
003900640000
ICP
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
IPR Duty Cycle
07E0221434
046285140634
3008
0DCA03E8000A
IPR %
Mass Fuel Desired (in milligrams perstroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3701
MTH: 000100010000
NAM: SYC
Trans. Fluid Temp.
07E1221674
046205160674
3010
000100080000
TFT
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
Old Oct 1, 2011 | 07:20 PM
TomCat-F350
Thank you for all your great information especially the Boost table and how to properly set it up. I will go out and do it now to have it working correctly. I understand the EOT and ECT should not exceed 12 degrees apart correct? What temp is normal for the EOT?
Old Oct 1, 2011 | 08:12 PM
weldworks54's Avatar
weldworks54
My 03 show 13.8 volts idling
Old Oct 2, 2011 | 11:58 AM
BLADE35's Avatar
BLADE35
Its 15* apart for ECT vs EOT to be in Ford Spec
these 2 gauges should also be 1-2* apart after a cold soak at startup
Also may want to watch FICM and volts at startup
the_auto_tech
Apr 23, 2013 11:39 PM
Gmangh15
Nov 16, 2011 09:11 AM
j-bar
Oct 18, 2011 05:01 AM
amdriven2liv
Mar 28, 2011 08:59 PM
kirkharrod
16
Feb 25, 2010 07:36 AM
