moisture problem
Old Oct 17, 2011 | 08:51 AM
tjprawitz's Avatar
tjprawitz
moisture problem
Im getting the moisture light. drained the trap the day before. drove 200 miles (started with a full tank). out of no where it died, wont start but moisture light is on and its not throwing any codes. drained the trap again, it started but not for long. how do i get the remainder of the moisture out of the system.
Old Oct 17, 2011 | 09:29 AM
dschuffert's Avatar
dschuffert
It is possible you got a batch of bad fuel from the last fill up. You may have to drain the tank and refill with fuel from a known good source.
Old Oct 17, 2011 | 10:07 AM
bismic's Avatar
bismic
Are you sure it is water in the fuel. drain the water trap into a glass jar. If you see two phases, you know you have water. if you don't see water, then the WIF sensor could just be corroded and could just need a good cleaning.
As far as the engine dieing, when did you last change fuel filters (and are you using Motorcraft or racor filters)?
Old Oct 17, 2011 | 04:37 PM
tjprawitz's Avatar
tjprawitz
using ford filters. changed them about 7000 miles ago. not sure its water now im suspecting icp or ficm problems. I just bought this truck in May and I think I inherited some problems. However, I did drain moisture trap did not notice anything peculiar. thanks guys.
Old Oct 17, 2011 | 04:49 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Clean the trap.....it's had water in it before and one one cleaned it.....pull it and you'll see.....cheap fix! Don't fix something that ain't broke....it gets expensive!
Old Oct 17, 2011 | 09:05 PM
tjprawitz's Avatar
tjprawitz
Ok, pretty sure it's not moisture now. Moving on to other solutions to my money pit. icp, ficm, cps. gotta find it sooner or later. maybe find a wrecked 7.3 and swap motors. LOL
Old Oct 17, 2011 | 09:14 PM
bismic's Avatar
bismic
Have you gone through the no-start troubleshooting thread in the Tech Folder?
Old Oct 17, 2011 | 09:52 PM
BLADE35's Avatar
BLADE35
You might want to look into a scangauge it would help rule things out
plus its good to monitor some things on the 6.0 like EOT vs ECT spread
roadpilot
Oct 28, 2018 06:17 PM
Tanner Jones
Dec 4, 2016 01:24 PM
pdarbs
Oct 28, 2010 03:05 PM
Jayybird
Oct 5, 2010 01:12 PM
naseflorio
6.4L Power Stroke Diesel
Sep 23, 2009 12:45 AM
